9248 010U500
9248 010U500
    BELDEN
    #18 PE/GIFHDPE SH FRPVC
9248 010U500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9248 Coax - 75 Ohm Coax For more Information please call 1-800-Belden1 General Description: 18 AWG solid .040" bare copper conductor, gas-injected foam HDPE insulation, Duofoil® + tinned copper braid shield (60% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 18 Solid BC - Bare Copper .040 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .180 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 60 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.270 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 1354) Bulk Cable Weight: 35 lbs/1000 ft. Max. Recommended Pulling Tension: 44 lbs. Min. Bend Radius/Minor Axis: 2.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CM AWM Specification: UL Style 1354 (30 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 6/U Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9248 Coax - 75 Ohm Coax Flame Test UL Flame Test: UL1685 UL Loading Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Plenum/Non-Plenum Plenum Number: 89248 and 82248 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .106 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.2 Nominal Velocity of Propagation: VP (%) 82 Nominal Delay: Delay (ns/ft) 1.24 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.4 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.6 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .30 5 .54 10 .70 50 1.5 100 2.0 200 2.8 400 4.0 700 5.3 900 6.1 1000 6.5 1500 8.3 Max. Operating Voltage - UL: Voltage 30 V RMS (UL AWM Style 1354); 300 V RMS (CM) Minimum Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5 450 23 Put Ups and Colors: Item # Putup Ship Weight Color 9248 010U1000 1,000 FT 37.000 LB BLACK Notes Item Desc 9248 010U500 500 FT 19.000 LB BLACK 9248 0101000 1,000 FT 38.000 LB BLACK C #18 PE/GIFHDPE SH FRPVC 9248 0101640 1,640 FT 63.960 LB BLACK C #18 PE/GIFHDPE SH CORE 9248 0103280 3,280 FT 121.360 LB BLACK C #18 PE/GIFHDPE SH FRPVC 9248 010500 500 FT 19.000 LB BLACK C #18 PE/GIFHDPE SH FRPVC #18 PE/GIFHDPE SH FRPVC #18 PE/GIFHDPE SH FRPVC Notes: C = CRATE REEL PUT-UP. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9248 Coax - 75 Ohm Coax Revision Number: 2 Revision Date: 08-13-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9248 010U500 价格&库存
很抱歉,暂时无法提供与“9248 010U500”相匹配的价格&库存,您可以联系我们找货
9248 010U500
  • 500+11.73754500+1.52585
