9316 060U1000
9316 060U1000
    BELDEN
    CBL 1PR 16AWG SHLD
9316 060U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9316 Multi-Conductor - 300V Power-Limited Tray Cable For more Information please call 1-800-Belden1 General Description: 16 AWG pairs stranded (19x29) tinned copper conductors, twisted pairs, PVC insulation, overall Beldfoil® shield (100% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 1 16 19x29 TC - Tinned Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .016 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 18 Inner Shield Drain Wire Stranding: 19x30 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .037 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.256 in. Pair Pair Color Code Chart: Number Color 1 Black & Red Pair Lay Length & Direction: Lay Length (in.) 2.750 Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +105°C Bulk Cable Weight: 41 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 2.560 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG, ITC-ER, PLTC-ER CEC/C(UL) Specification: CMG AWM Specification: UL Style 2464 (300 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 3 10-24-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9316 Multi-Conductor - 300V Power-Limited Tray Cable EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 FT4 Loading CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .16 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 68 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 121 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.200 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 5.700 Ohm/1000 ft Max. Operating Voltage - UL: Voltage 300 V RMS Put Ups and Colors: Item # Putup Ship Weight Color 9316 060U1000 1,000 FT 42.000 LB CHROME Notes Item Desc 2 #16 PVC FS PVC 9316 060U500 500 FT 22.000 LB CHROME 2 #16 PVC FS PVC 9316 0601000 1,000 FT 43.000 LB CHROME 9316 06010000 10,000 FT 470.000 LB CHROME 9316 0605000 5,000 FT 215.000 LB 2 #16 PVC FS PVC CZ 2 #16 PVC FS PVC Z 2 #16 PVC FS PVC Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 4 Revision Date: 05-17-2015 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 3 10-24-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9316 Multi-Conductor - 300V Power-Limited Tray Cable Page 3 of 3 10-24-2016
9316 060U1000
物料型号:9316 Multi-Conductor - 300V Power-Limited Tray Cable
器件简介: - 16 AWG对绞线,每对由19根29号镀锡铜导体组成。 - PVC绝缘,整体Beldfoil®屏蔽(100%覆盖率),PVC外护套。
引脚分配: - 总导体数:2 - 内部屏蔽材料:铝箔-聚酯带,覆盖率100%。 - 内部屏蔽导线:AWG 18,19x30 TC - 镀锡铜。
参数特性: - 工作温度范围:-30°C至+105°C。 - 电缆重量:41磅/1000英尺。 - 最大推荐拉力:40磅。 - 最小弯曲半径/次要轴:2.560英寸。
功能详解: - 电缆符合多个标准和环境计划,包括NEC/UL、CEC/C(UL)、AWM、EU指令2011/65/EU(ROHS II)等。 - 通过多种火焰测试,如UL1685 FT4、CSA FT4、IEEE 1202。 - 具有耐阳光性,不是吊顶/非吊顶电缆。
应用信息: - 电缆适用于多种环境和应用,但不适合作为吊顶电缆。
封装信息: - 电缆外护套材料:PVC。 - 外护套厚度:0.037英寸。 - 电缆整体标称直径:0.256英寸。 - 电缆颜色:铬色。 - 电缆包装信息:1000英尺、500英尺、1000英尺、10,000英尺和5,000英尺,重量分别为42.000磅、22.000磅、43.000磅、470.000磅和215.000磅。
9316 060U1000 价格&库存
很抱歉,暂时无法提供与“9316 060U1000”相匹配的价格&库存,您可以联系我们找货
