9451D A5Q2000
9451D A5Q2000
    BELDEN
    2 BONDED #22 FSPR PO FRPVC
9451D A5Q2000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9451D Multi-Conductor - Double-Pair Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductors, polyolefin insulation, dual twisted pairs, overall Beldfoil® shield (100% coverage), 22 AWG stranded TC drain wire, PVC jacket in zip-cord construction. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 22 7x30 TC - Tinned Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PO - Polyolefin .008 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 22 7x30 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .020 Overall Cable Overall Nominal Diameter: 0.135 x 0.270 in. Pair Pair Color Code Chart: Number Color 1 Black & Red 2 Black & Red Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +105°C UL Temperature Rating: 105°C Bulk Cable Weight: 27 lbs/1000 ft. Max. Recommended Pulling Tension: 54 lbs. Min. Bend Radius/Minor Axis: 1.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9451D Multi-Conductor - Double-Pair Cable EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 45 Nom. Inductance: Inductance (µH/ft) .16 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 34 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 67 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.5 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14.1 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14.3 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.9 Amps per conductor @ 25°C Notes (Overall) Notes: The jacket and shield are bonded so both can be removed on automatic stripping equipment. Drain wire is inside foil shield. For cross-connect use with 1814R (et. al.) Snake Cables. Put Ups and Colors: Item # Putup Ship Weight Color 9451D A5QU1000 1,000 FT 29.000 LB RED & GREEN 2 BONDED #22 FSPR PO FRPVC 9451D A5Q2000 2,000 FT 58.000 LB RED & GREEN 2 BONDED #22 FSPR PO FRPVC 9451D G04U1000 1,000 FT 29.000 LB RED & PURPLE 2 BONDED #22 FSPR PO FRPVC 9451D J77U1000 1,000 FT 29.000 LB USE 061 2 BONDED #22 FSPR PO FRPVC 9451D 053U1000 1,000 FT 29.000 LB RED & GRAY 2 BONDED #22 FSPR PO FRPVC Revision Number: 1 Notes Item Desc Revision Date: 08-22-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9451D Multi-Conductor - Double-Pair Cable Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9451D A5Q2000 价格&库存
很抱歉,暂时无法提供与“9451D A5Q2000”相匹配的价格&库存,您可以联系我们找货
