AX101437
AX101437
    BELDEN
    Module
    INTERFACE PLATE 4-PORT, WHI
AX101437 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101437 Faceplates and Panels - Interface Plates 4 Port Single Gang Flush For more Information please call 1-800-Belden1 General Description: Interface Plates 4 Port Single Gang Flush Usage (Overall) Suitable Applications: - Compatible with a variety of modules that are suitable for use with Belden IBDN Systems 10GX, 4800,3600, 2400 and 1200. Related Parts: - Compatible with 10GX, CAT6+ and CAT5E MDVO-style Modular Jacks and MDVO Multimedia Modules Physical Characteristics (Connectivity) Capacity Max. Capacity: 4 ports Access Front Connection: Flush Dimensions Dimensions: Height (in.) Width (in.) Depth (in.) 4.490 3.000 0.460 Materials Materials: Description Material Plate Plastic - UL94V-0 Color Color: White Weight Weight: 0.110 lbs. Included Parts Included Parts: blank, 6-32 screw, carton label, clear window, installation sheet Packaging Packaging: Individually packaged in a plastic bag. Mechanical Characteristics (Connectivity) Connector/Hardware Retention: 20 lbs. Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2006 MII Order #39 (China RoHS): EUP 50 Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes Transmission Characteristics (Connectivity) Notes (Overall) Notes: For proper installation refer to Installation Guide PX101806 included with the product or visit our web site at http://www.belden.com Page 1 of 2 03-13-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX101437 Faceplates and Panels - Interface Plates 4 Port Single Gang Flush Product Family Part Numbers: Description Gray Interface Plate Flush 2-port Single Gang AX101431 AX101432 AX101433 AX101434 AX102582 Almond White Black Ivory Interface Plate Flush 4-port Single Gang AX101435 AX101436 AX101437 AX101438 AX102583 Interface Plate Flush 6-port Single Gang AX101439 AX101440 AX101441 AX101442 AX102584 Interface Surface Adapter Box Single gang AX101474 AX101475 AX101476 AX101477 AX102589 Put Ups and Colors: Item # Putup Ship Weight Color AX101437 1 EA 0.038 KG WHITE Revision Number: 0 Notes Item Desc INTERFACE PLATE 4-PORT, WHI Revision Date: 06-02-2009 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 03-13-2017
AX101437 价格&库存
很抱歉,暂时无法提供与“AX101437”相匹配的价格&库存,您可以联系我们找货
