C7GBSY
C7GBSY
    BELDEN
    BELDEN - C7GBSY - Multicore Cable, Per Metre, Screened, 7 Core, 0.75 mm²
C7GBSY 数据手册
MachFlex 375 SY Cables Armored (SY) PVC Control Cables Galvanized Steel Wire Braid (GSWB) Excellent Mechanical Protection Applications Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more. General Reference Standards • • • • • DIN VDE 0295, IEC 60228, BS6360 DIN EN 50290-2-22, DIN VDE 0207-363-4-1 IEC 60227-5, VDE 0281 DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 RoHS & REACH Directives Construction and Performance 1. Conductor Material Stranded bare copper (DIN VDE 0295 Class 5) 2. Insulation Material & Color PVC (polyvinyl chloride). A) Up to 5 cores: color-coded. From 6 cores: Belden MachFlex Color code. B) G = with GN-YE protective conductor; X = without protective conductor. 3. Braid Shield Material GSWB (Galvanized Steel Wire Braid) 4. Jacket / Sheath Material PVC (polyvinyl chloride) 5. Flame Retardancy VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 6. Voltage Rating (Uo/U) Up to 1.5 mm2: 300 / 500 V From 2.5 mm2: 450 / 750 V 7. Oil Resistant DIN EN 50290-2-22 (TM54) 8. Temperature Range -5 °C TO +70 °C (Occasional movement) -40 °C TO +80 °C (Fixed installation) 9. Bending Radius 20 x OD (Occasional movement) 6 x OD (Fixed installation) 10. Other Properties Good UV resistance, chemical resistance & flexibility MachFlex 375 SY Armored (SY) PVC Control Cables GALVANLIZED STEEL WIRE BRAID SHIELD (GSWB) CABLE WITH (G) PROTECTIVE GROUND 5 4 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.7 8.3 8.8 9.5 11.9 14.5 1 = Conductor 2 = Insulation 3 = Inner Sheath 4 = Galvanized Steel Wire Braid Shield 5 = Outer Sheath Conductor 0.75 mm2 Copper Weight (kg/km) 14.40 19.20 24.00 33.60 58.00 96.70 EMEA Part Code C3GASY C4GASY C5GASY C7GASY C12GASY C20GASY APAC Part Code C3G0.5SY C4G0.5SY C5G0.5SY C7G0.5SY C12G0.5SY C20G0.5SY Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 8.3 8.9 9.5 10.2 12.9 15.9 Copper Weight (kg/km) 21.60 28.80 36.00 50.00 86.00 143.30 EMEA APAC Part Code Part Code C3GBSY C3G0.75SY C4GBSY C4G0.75SY C5GBSY C5G0.75SY C7GBSY C7G0.75SY C12GBSY C12G0.75SY C20GBSY C20G0.75SY Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.7 28.80 4 9.4 38.40 5 10.1 48.00 7 10.8 67.00 12 14.0 115.00 20 16.9 192.00 Conductor 2.50 mm2 EMEA Part Code C3GCSY C4GCSY C5GCSY C7GCSY C12GCSY C20GCSY APAC Part Code C3G1.0SY C4G1.0SY C5G1.0SY C7G1.0SY C12G1.0SY C20G1.0SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 9.3 43.00 4 10.0 58.00 5 10.8 72.00 7 11.6 101.00 12 15.1 173.00 20 18.4 288.30 Conductor 4.00 mm2 EMEA Part Code C3GDSY C4GDSY C5GDSY C7GDSY C12GDSY C20GDSY APAC Part Code C3G1.5SY C4G1.5SY C5G1.5SY C7G1.5SY C12G1.5SY C20G1.5SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 12.6 72.00 4 13.9 96.00 5 15.1 120.00 7 16.4 168.00 9 19.9 216.00 12 21.4 288.00 Conductor 6.00 mm2 EMEA Part Code C3GESY C4GESY C5GESY C7GESY C9GESY C12GESY APAC Part Code C3G2.5SY C4G2.5SY C5G2.5SY C7G2.5SY C9G2.5SY C12G2.5SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 14.4 115.00 4 15.7 154.00 5 17.1 192.00 7 18.6 269.00 9 22.7 345.90 12 24.5 461.00 Conductor 10.00 mm2 EMEA Part Code C3GFSY APAC Part Code C3G4SY C4GFSY C5GFSY C7GFSY C9GFSY C12GFSY C4G4SY C5G4SY C7G4SY C9G4SY C12G4SY No. of Cores 3 4 5 7 9 EMEA Part Code C3GGSY C4GGSY C5GGSY C7GGSY C9GGSY APAC Part Code C3G6SY C4G6SY C5G6SY C7G6SY C9G6SY No. of Cores 3 4 5 7 9 EMEA Part Code C3GHSY C4GHSY C5GHSY C7GHSY C9GHSY APAC Part Code C3G10SY C4G10SY C5G10SY C7G10SY C9G10SY EMEA Part Code C3GJSY C4GJSY C5GJSY APAC Part Code C3G25SY C4G25SY C5G25SY Nom. Overall Diameter (mm) 15.9 17.4 19.0 20.7 25.4 Copper Weight (kg/km) 172.80 230.00 288.00 403.00 518.10 Conductor 16.00 mm2 No. of Cores 3 4 5 Nom. Overall Diameter (mm) 23.0 25.3 27.9 Copper Weight (kg/km) 460.50 614.00 768.00 Nom. Overall Diameter (mm) 18.6 20.4 22.3 24.4 30.0 Copper Weight (kg/km) 288.00 384.00 480.00 672.00 864.00 Conductor 25.00 mm2 EMEA Part Code C3GISY C4GISY C5GISY APAC Part Code C3G16SY C4G16SY C5G16SY No. of Cores 3 4 5 Nom. Overall Diameter (mm) 25.9 28.6 31.2 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 720.00 960.00 1,200.00 MachFlex 375 SY Armored (SY) PVC Control Cables GALVANLIZED STEEL WIRE BRAID SHIELD (GSWB) CABLE WITHOUT(G) PROTECTIVE GROUND 5 4 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.7 8.3 8.8 9.5 11.9 14.5 1 = Conductor 2 = Insulation 3 = Inner Sheath 4 = Galvanized Steel Wire Braid Shield 5 = Outer Sheath Conductor 0.75 mm2 Copper Weight (kg/km) 14.40 19.20 24.00 33.60 58.00 96.70 EMEA Part Code C3XASY C4XASY C5XASY C7XASY C12XASY C20XASY APAC Part Code C3X0.5SY C4X0.5SY C5X0.5SY C7X0.5SY C12X0.5SY C20X0.5SY Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 8.3 8.9 9.5 10.2 12.9 15.9 Copper Weight (kg/km) 21.60 28.80 36.00 50.00 86.00 143.30 EMEA Part Code C3XBSY C4XBSY C5XBSY C7XBSY C12XBSY C20XBSY APAC Part Code C3X0.75SY C4X0.75SY C5X0.75SY C7X0.75SY C12X0.75SY C20X0.75SY Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.7 28.80 4 9.4 38.40 5 10.1 48.00 7 10.8 67.00 12 14.0 115.00 20 16.9 192.00 Conductor 2.50 mm2 EMEA Part Code C3XCSY C4XCSY C5XCSY C7XCSY C12XCSY C20XCSY APAC Part Code C3X1.0SY C4X1.0SY C5X1.0SY C7X1.0SY C12X1.0SY C20X1.0SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 9.3 43.00 4 10.0 58.00 5 10.8 72.00 7 11.6 101.00 12 15.1 173.00 20 18.4 288.30 Conductor 4.00 mm2 EMEA Part Code C3XDSY C4XDSY C5XDSY C7XDSY C12XDSY C20XDSY APAC Part Code C3X1.5SY C4X1.5SY C5X1.5SY C7X1.5SY C12X1.5SY C20X1.5SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 12.6 72.00 4 13.9 96.00 5 15.1 120.00 7 16.4 168.00 9 19.9 216.00 12 21.4 288.00 Conductor 6.00 mm2 EMEA Part Code C3XESY C4XESY C5XESY C7XESY C9XESY C12XESY APAC Part Code C3X2.5SY C4X2.5SY C5X2.5SY C7X2.5SY C9X2.5SY C12X2.5SY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 14.4 115.00 4 15.7 154.00 5 17.1 192.00 7 18.6 269.00 9 22.7 345.90 12 24.5 461.00 Conductor 10.00 mm2 EMEA Part Code C3XFSY C4XFSY C5XFSY C7XFSY C9XFSY C12XFSY APAC Part Code C3X4SY C4X4SY C5X4SY C7X4SY C9X4SY C12X4SY No. of Cores 3 4 5 7 9 EMEA Part Code C3XGSY C4XGSY C5XGSY C7XGSY C9XGSY APAC Part Code C3X6SY C4X6SY C5X6SY C7X6SY C9X6SY No. of Cores 3 4 5 7 9 EMEA Part Code C3XHSY C4XHSY C5XHSY C7XHSY C9XHSY APAC Part Code C3X10SY C4X10SY C5X10SY C7X10SY C9X10SY EMEA Part Code C3XJSY C4XJSY C5XJSY APAC Part Code C3X25SY C4X25SY C5X25SY Nom. Overall Diameter (mm) 15.9 17.4 19.0 20.7 25.4 Copper Weight (kg/km) 172.80 230.00 288.00 403.00 518.10 Conductor 16.00 mm2 No. of Cores 3 4 5 Nom. Overall Diameter (mm) 23.0 25.3 27.9 Copper Weight (kg/km) 460.50 614.00 768.00 Nom. Overall Diameter (mm) 18.6 20.4 22.3 24.4 30.0 Copper Weight (kg/km) 288.00 384.00 480.00 672.00 864.00 Conductor 25.00 mm2 EMEA Part Code C3XISY C4XISY C5XISY APAC Part Code C3X16SY C4X16SY C5X16SY No. of Cores 3 4 5 Nom. Overall Diameter (mm) 25.9 28.6 31.2 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 720.00 960.00 1,200.00
C7GBSY 价格&库存
很抱歉,暂时无法提供与“C7GBSY”相匹配的价格&库存,您可以联系我们找货
