ECX-01U
ECX-01U
    BELDEN
    ECX-01U
ECX-01U 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION ECX-01U Faceplates and Panels - FX ECX 1U Housing 19" width For more Information please call 1-800-Belden1 General Description: FiberExpress ECX Patch Panel Housing 1U, holds 2 ECX adapter frames or cassettes Image Image: Usage (Overall) Suitable Applications: FiberExpress Solutions, Backbone, Telecommunications Room, Main Distribution Room, Data Centers Related Parts: FiberExpress ECX Frames, Cassettes and Housing Accessories Physical Characteristics (Connectivity) Capacity Access Termination Area: Front Sliding Drawer Dimensions Dimensions: Height (in.) Width (in.) Depth (in.) 1.732 19.122 17.564 Materials Materials: Description Material Housing Steel Housing PC/ABS Housing Polycarbonate Color Color: Black, White Weight Weight: 4.440 lbs. Included Parts Included Parts: Screws (12-24); Screws (10-32); Tie Wraps; Velcro Straps; Identification Labels; Quick Installation Guides; Strain Reliefs Packaging Packaging: Individually packaged in a cardboard box. Mechanical Characteristics (Connectivity) Storage Temperature Range: -40°C To +70°C Operating Temperature Range: -10°C To +60°C Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Page 1 of 2 07-31-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION ECX-01U Faceplates and Panels - FX ECX 1U Housing 19" width EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 02/23/2009 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: EIA/ECA 310 Suitability Suitability - Indoor: Yes Transmission Characteristics (Connectivity) Notes (Overall) Notes: For more information, please refer to our web site at http://www.belden.com. Installation Guide: PX106483 Product Family Part Numbers: Description Item Number FX ECX Patch Panel Housing 1U ECX-01U FX ECX Patch Panel Housing 2U ECX-02U FX ECX Patch Panel Housing 4U ECX-04U Put Ups and Colors: Item # Putup Ship Weight ECX-01U 1 EA 14.800 LB Revision Number: 0 Color Notes Item Desc FX ECX 1U PATCH PANEL HOUSING Revision Date: 09-26-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 07-31-2017
ECX-01U
- 物料型号:ECX-01U,是FiberExpress ECX Patch Panel Housing 1U,适用于19英寸宽度的机架。 - 器件简介:该产品是FiberExpress解决方案的一部分,适用于主干线、电信室、主配线室和数据中心。它包含一个前滑动抽屉,可以容纳2个ECX适配器框架或卡带。 - 引脚分配:未在文档中明确提及。 - 参数特性: - 材料:外壳材料包括钢、PC/ABS和聚碳酸酯。 - 颜色:黑色和白色。 - 重量:约4.44磅。 - 尺寸:高度1.732英寸,宽度19.122英寸,深度17.564英寸。 - 适用温度范围:存储温度范围为-40°C至+70°C,操作温度范围为-10°C至+60°C。 - 包含部件:螺丝(12-24)、螺丝(10-32)、扎带、魔术贴带、识别标签、快速安装指南和拉力释放装置。 - 功能详解:适用于室内使用,符合EIA/ECA310电信标准。 - 应用信息:适用于FiberExpress解决方案,包括主干线、电信室、主配线室和数据中心。 - 封装信息:每个产品单独包装在纸板箱中。
ECX-01U 价格&库存
很抱歉,暂时无法提供与“ECX-01U”相匹配的价格&库存,您可以联系我们找货
