1119A 0101000
1119A 0101000
    BELDEN
    CBL 3COND 16AWG SHLD
1119A 0101000 数据手册
Part Number: 1119A 600V Tray, (1 triad) 16 AWG (7x24) BC, PVC-NYL/PVC, Foil Shld, TC-ER Product Description One 16 AWG triad stranded (7x24) bare copper conductors, twisted triads, PVC/Nylon insulation, overall Beldfoil® shield (100% coverage), PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 16 7x24 Material No. of Triads BC - Bare Copper 1 Conductor Count: 3 Total Number of Pairs: 1 Total Number of Triads: N/A AWG Size: 16 Insulation Material Nominal Diameter PVC/Nylon - Polyvinyl Chloride/Nylon 0.101 in Color Chart Number Color 1 Red 2 Black 3 Blue Color Chart 2 Number 1 Color Black & Red & Blue Inner Shield Material Drainwire AWG Drainwire Construction n x D 7x26 mm TC - Tinned Copper Outer Shield Material Type Material Material Trade Name Coverage [%] Drainwire Material Tape Aluminum Foil-Polyester Tape Beldfoil® 100 % Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness Ripcord PVC - Polyvinyl Chloride 0.315 in 0.047 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 3.67 Ohm/1000ft Voltage 4.99 Ohm/1000ft Drainwire AWG TC - Tinned Copper 18 Yes UL Voltage Rating 600V RMS 150 V RMS Temperature Range UL Temp Rating: 75°C Dry, 90°C Wet Wet Temp Range: -30°C To +75 °C Dry Temp Range: -30°C To +90 °C Mechanical Characteristics Bulk Cable Weight: 67 lbs/1000ft Max Recommended Pulling Tension: 129 lbs Min Bend Radius/Minor Axis: 3.1 in Standards NEC/(UL) Specification: TC-ER, NPLF Other Specification: ICEA S-73-532 (WC57), S-61-402 Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Burial: Yes Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Sunlight Resistance: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1685 UL Loading CSA Flammability: FT4 ICEA Flammability: T-29-520 IEEE Flammability: 1202 Part Number Plenum (Y/N): No Variants Item # 1119A 0101000 Color Footnote BLACK C Z 1119A 01010000 BLACK C Z 1119A 010500 BLACK C Z Footnote: C - CRATE REEL PUT-UP. Footnote: Z - FINAL PUT-UP MAY VARY (= OR -) 10% FOR SPOOLS OR REELS AND (+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Product Notes Notes: Alternate color coding available upon request. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
1119A 0101000 价格&库存
很抱歉,暂时无法提供与“1119A 0101000”相匹配的价格&库存,您可以联系我们找货
