Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1345F Multi-Conductor - High-Flex DeviceBus® for ODVA DeviceNet™
For more Information
please call
1-800-Belden1
General Description:
15 and 18 AWG stranded tinned copper conductors, PVC insulation (power), FPE insulation (data),
individually foil shielded (100% coverage) plus an overall tinned copper braid (65% coverage),
sunlight/oil-resistant TPE jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material
1
15
65x33
TC - Tinned Copper
1
18
65x36
TC - Tinned Copper
Total Number of Conductors:
4
Insulation
Insulation Material:
Insulation Material
AWG
PVC - Polyvinyl Chloride
15
FPE - Foam Polyethylene 18
Inner Shield
Inner Shield Material:
Layer #
Type Inner Shield Material
Coverage (%)
15 AWG Pair Tape Aluminum Foil-Polyester Tape 100
18 AWG Pair Tape Aluminum Foil-Polyester Tape 100
Outer Shield
Outer Shield Material:
Type Outer Shield Material Coverage (%)
Braid TC - Tinned Copper
65
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
18
65x36
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
TPE - Thermoplastic Elastomer .060
Overall Cable
Overall Nominal Diameter:
0.480 in.
Pair
Pair Color Code Chart:
Number
Color
1 (15 AWG) Red & Black
2 (18 AWG) Blue & White
Mechanical Characteristics (Overall)
Operating Temperature Range:
-30°C To +75°C
UL Temperature Rating:
75°C (UL AWM Style 20201)
Bulk Cable Weight:
133 lbs/1000 ft.
Max. Recommended Pulling Tension:
205 lbs.
Min. Bend Radius/Minor Axis:
4.600 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMG, PLTC-ER
Page 1 of 3
01-05-2017
CEC/C(UL) Specification:
CMG
AWM Specification:
UL Style 20201 (600 V 75°C)
CSA Specification:
I/II A
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Other Specification:
ODVA Class 2 Thick
Flame Test
UL Flame Test:
UL1685 FT4 Loading
CSA Flame Test:
FT4
Suitability
Sunlight Resistance:
Yes
Oil Resistance:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Unaveraged Impedance:
Description
Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Impedance (Ohm)
18 AWG Pair Only
120
Nom. Inductance:
Description
Inductance (µH/ft)
15 AWG Pair Only .174
Nom. Capacitance Conductor to Conductor:
Description
Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Capacitance (pF/ft)
18 AWG Pair Only 1
12.0
Nominal Velocity of Propagation:
Description
VP (%)
18 AWG Pair Only 75
Maximum Delay:
Description
Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Delay (ns/ft)
18 AWG Pair Only
1.36
Nom. Conductor DC Resistance:
Description DCR @ 20°C (Ohm/1000 ft)
15 AWG
3.6
18 AWG
6.9
Nominal Outer Shield DC Resistance:
1.8
Max. Attenuation:
Description
Freq. (MHz)
.13 18 AWG Pair Only .125
.26
.500
.40
1.00
Max. Operating Voltage - UL:
Voltage
Description
300 V RMS C(UL) AWM
Max. Recommended Current:
Description Current
15 AWG
8.0 Amps
18 AWG
5.0 Amps
Page 2 of 3
01-05-2017
Notes (Overall)
Notes: High-Flex. Thick. Meter marks on jacket to aid users in installation. ODVA DeviceNet is an Open DeviceNet Vendor Association, Inc. trademark. Jacket printed "1PR16"
instead of "1PR15" due to UL requirements for CMG Listing.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1345F T5U1000
1,000 FT
133.000 LB
GRAY T5U
C
2 #15, 2 #18 SH TPE
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 2
Revision Date: 08-01-2012
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“1345F T5U1000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 305+227.27449305+29.45910
- 610+198.85428610+25.77530
- 国内价格 香港价格
- 1000+126.798351000+16.43548
