1671J 010100
1671J 010100
    BELDEN
    #24 TFE BRD TINNED COAX PVC
1671J 010100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1671J Coax - 50 Ohm Microwave Cable For more Information please call 1-800-Belden1 General Description: RG-405/U type, 24 AWG solid .020" silver-plated copper-covered steel conductor, TFE Teflon® insulation, copper-tin composite shield (100% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 24 Solid Dia. (in.) SPCCS - Silver Plated Copper Covered Steel .020 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Trade Name Insulation Material Teflon® Dia. (in.) TFE - Tetrafluoroethylene .062 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Tape Copper Foil 100 2 Braid Tin-Filled Composite 100 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.127 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +105°C UL Temperature Rating: 105°C (UL AWM Style 10245) Non-UL Temperature Rating: 105°C Bulk Cable Weight: 16 lbs/1000 ft. Max. Recommended Pulling Tension: 26 lbs. Min. Bend/Installation: 0.125 in. Min. Flexing Radius: 0.375 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 10245 (30 V 105°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 405/U Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1671J Coax - 50 Ohm Microwave Cable Flame Test Other Flame Test: Horizontal Wire Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) .07 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 29.5 Nominal Velocity of Propagation: VP (%) 69.5 Nominal Delay: Delay (ns/ft) 1.46 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 64.2 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10.2 Maximum VSWR: Freq. (MHz) Max. VSWR 500 1.1:1 20000 1.3:1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 500 15.0 1000 22.2 2000 32.8 3000 41.2 5000 54.9 7000 66.4 10000 81.2 15000 102 18000 113 20000 120 Max. Power Rating: Freq. (MHz) Rating (W) 500 180 1000 119 2000 79 3000 62 5000 46 7000 37 10000 30 15000 24 18000 21 20000 20 Max. Operating Voltage - UL: Voltage 30 V RMS (UL AWM Style 10245) Max. Operating Voltage - Non-UL: Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1671J Coax - 50 Ohm Microwave Cable Voltage 1500 V RMS Misc. Information (Overall) Notes (Overall) Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc. Put Ups and Colors: Item # Putup Ship Weight Color 1671J 010100 100 FT 2.400 LB BLACK Notes Item Desc 1671J 0101000 1,000 FT 17.000 LB BLACK V #24 TFE BRD TINNED COAX PVC 1671J 010500 500 FT 9.500 LB BLACK V #24 TFE BRD TINNED COAX PVC #24 TFE BRD TINNED COAX PVC Notes: V = 250' PUT-UP EXACT LENGTH MAXIMUM OF 3 PIECESMINIMUM LENGTH 50'500' PUT-UP EXACT LENGTH MAXIMUM OF 5 PIECESMINIMUM LENGTH 50' Revision Number: 5 Revision Date: 01-15-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
1671J 010100 价格&库存
很抱歉,暂时无法提供与“1671J 010100”相匹配的价格&库存,您可以联系我们找货
