1855A 0091000
1855A 0091000
    BELDEN
    #23 PE/GIFHDPE SH FR PVC
1855A 0091000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1855A Coax - Sub-Miniature For more Information please call 1-800-Belden1 General Description: 23 AWG solid .023" bare copper conductor, gas-injected foam HDPE insulation, Duofoil® + tinned copper braid shield (95% coverage), PVC jacket. Usage (Overall) Suitable Applications: SMPTE 2081-1 6 Gb/s UHDTV, SMPTE 424M 3 Gb/s HD-SDI 1080p Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 23 Solid BC - Bare Copper .023 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .102 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.159 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 17 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 1.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1855A Coax - Sub-Miniature MII Order #39 (China RoHS): Yes RG Type: Sub-miniature 59/U Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1855P Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .107 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.3 Nominal Velocity of Propagation: VP (%) 82 Nominal Delay: Delay (ns/ft) 1.22 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 20.1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.390 3.580 0.780 5.000 0.920 6.000 1.000 7.000 1.080 10.000 1.200 12.000 1.300 25.000 1.800 67.500 2.830 71.500 2.930 88.500 3.220 100.000 3.390 135.000 3.840 143.000 4.000 180.000 4.410 270.000 5.440 360.000 6.340 540.000 7.850 720.000 9.150 750.000 9.310 1000.000 10.890 1500.000 13.380 2000.000 15.640 2250.000 16.680 3000.000 19.650 4500.000 24.350 6000.000 28.970 Max. Operating Voltage - UL: Voltage 300 V RMS Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1855A Coax - Sub-Miniature Other Electrical Characteristic 1: TDR Impedance: 75 +/- 1.5 Ohms Other Electrical Characteristic 2: Return Loss: Fixed bridge and termination. Minimum Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5.000 1600.000 23.000 1601.000 4500.000 21.000 4500.000 6000.000 15.000 Sweep Test Sweep Testing: 100% Sweep tested 5 MHz to 6 GHz. Misc. Information (Overall) Notes (Overall) Notes: Also available in 4.5 GHz multi-coax bundled versions. See 7787A through 7792A. Put Ups and Colors: Item # Putup Ship Weight Color 1855A N3UN1000 1,000 FT 21.000 LB GREEN, MIL 1855A N3U1000 1,000 FT 19.000 LB GREEN, MIL 1855A 001N1000 1,000 FT 21.000 LB BROWN 1855A 0011000 1,000 FT 19.000 LB BROWN 1855A 002N1000 1,000 FT 21.000 LB RED 1855A 0021000 1,000 FT 19.000 LB RED 1855A 003N1000 1,000 FT 21.000 LB ORANGE 1855A 0031000 1,000 FT 19.000 LB ORANGE 1855A 004N1000 1,000 FT 21.000 LB YELLOW 1855A 0041000 1,000 FT 19.000 LB YELLOW 1855A 006N1000 1,000 FT 21.000 LB BLUE, LIGHT 1855A 0061000 1,000 FT 19.000 LB BLUE, LIGHT 1855A 007N1000 1,000 FT 21.000 LB VIOLET 1855A 0071000 1,000 FT 19.000 LB VIOLET 1855A 008N1000 1,000 FT 21.000 LB GRAY 1855A 0081000 1,000 FT 19.000 LB GRAY 1855A 009N1000 1,000 FT 21.000 LB WHITE 1855A 0091000 1,000 FT 19.000 LB WHITE 1855A 010N1000 1,000 FT 21.000 LB BLACK 1855A 0101000 1,000 FT 19.000 LB BLACK 1855A 010500 500 FT 9.500 LB BLACK Notes Item Desc #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC C #23 PE/GIFHDPE SH FR PVC #23 PE/GIFHDPE SH FR PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 13 Revision Date: 06-17-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1855A 0091000 价格&库存
很抱歉,暂时无法提供与“1855A 0091000”相匹配的价格&库存,您可以联系我们找货
1855A 0091000
  • 1000+10.034921000+1.30203
