Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
3087A Multi-Conductor - DeviceBus® for Honeywell Smart Distributed System
For more Information
please call
1-800-Belden1
General Description:
22 AWG stranded tinned copper conductors, PVC insulation (power), FPE insulation (data), each pair
individually Beldfoil® shielded (100% coverage), PVC jacket
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material Dia. (in.)
2
22
19x34
TC - Tinned Copper .030
Total Number of Conductors:
4
Insulation
Insulation Material:
Insulation Material
AWG
PVC - Polyvinyl Chloride
22 AWG (Power Pair)
FPE - Foam Polyethylene 22 AWG (Data Pair)
Insulation Resistance:
10000 Mega-Ohm
Inner Shield
Inner Shield Material:
Inner Shield Trade Name Type Inner Shield Material
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
Outer Shield
Outer Shield Material:
Unshielded
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
22
19x34
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Overall Cable
Overall Nominal Diameter:
0.290 in.
Pair
Pair Color Code Chart:
Number
Color
1 (Power Pair) Brown & Blue
2 (Data Pair)
Black & White
Pair Lay Length & Direction:
Lay Length (in.)
2.000
Mechanical Characteristics (Overall)
Storage Temperature Range:
-40°C To +80°C
Operating Temperature Range:
-30°C To +80°C
UL Temperature Rating:
80°C (UL AWM Style 2464)
Bulk Cable Weight:
33 lbs/1000 ft.
Max. Recommended Pulling Tension:
47.500 lbs.
Min. Bend Radius/Minor Axis:
2.900 in.
Page 1 of 3
01-05-2017
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CL2
AWM Specification:
UL Style 2464 (30 V 80°C) (I/II A)
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
10/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
UL1685 UL Loading
CSA Flame Test:
FT1
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Unaveraged Impedance:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Impedance (Ohm)
Data
120
Nom. Capacitance Conductor to Conductor:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Capacitance (pF/ft)
Data
1
12.0
Nominal Velocity of Propagation:
Description VP (%)
Data
76
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
17.5
Nominal Outer Shield DC Resistance:
7.9
Nom. Attenuation:
Description Freq. (MHz) Attenuation (dB/100 ft.)
Data
.125
.23
.500
.42
1.0
.60
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Current
3 Amps per conductor @ 25°C
Notes (Overall)
Notes: Micro Cable (Drop)
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
3087A U3R1000
1,000 FT
41.000 LB
GRAY U3R
C
#22 FS PR, #22 FS PR PVC
3087A U3R2000
2,000 FT
84.000 LB
GRAY U3R
C
3087A U3R500
500 FT
20.500 LB
GRAY U3R
C
3087A U3R5000
5,000 FT
210.000 LB
GRAY U3R
CZ
Notes:
C = CRATE REEL PUT-UP.
Page 2 of 3
01-05-2017
Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN.
Revision Number: 1
Revision Date: 04-21-2008
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“3087A U3R1000”相匹配的价格&库存,您可以联系我们找货
