A BELDEN BRAND
Diamond Drop Hardware
Drop Wire Clamps for CATV and Telephone Cable
Universal Messenger Cable Drop Wire Clamp
•• Permits cable to “float” free, fully protected from strain and chafing.
•• Drop clamp for the suspension of a messengered drop cable between the
pole, midspan and house.
•• For use with RG59, RG6 and other cables
•• Stainless steel bail wire and aluminum body.
Installation:
Part Number
Description
SC02MFA-SS
Universal Messenger Drop Wire Clamp
1. Begin separation of the messenger wire from the
cable using the end-edge of the SC02MFA-SS Drop
Clamp.
Note: Never use a knife or other sharp tool to
separate messenger and cable.
2. Fit the cable and messenger wire into the SCO2MFASS Drop Clamp as shown, so that the Clamp Bail is
between the two.
3. Grasp the separated end of the messenger and cable
with one hand and grip the Clamp Body, as shown,
with your other hand. Then, pull the SC02MFA-SS
back, in a straight line, separating the length of
messenger wire needed to make the wrap; about 15
to 18-inches.
4. Pull the messenger wire around the center of the
bearing surface as shown, toward the rear or dropside of the Clamp.
Note: If at the house end of the drop, this will be
done while tensioning or “sagging” the drop.
5. Pass the messenger wire through the “L” Slots and
begin the wrap about the SC02MFA-SS body, as
shown.
Inner
Pack
Outer
Pack
125
1
2
3
4
5
6. Continue the messenger wire wrap for two full turns.
7. Pass the messenger wire through the “L” Slot, as
shown, to the drop-side of the SC02MFA-SS and cut
the excess wire away, or ground it to the strand.
Note: For drop cable with larger messenger wire, one
wrap is sufficient. Wrap the end of the wire around
the end of the SC02MFA-SS and bring it back up the
“L” Slots, then cut away the excess, or ground it to
the strand.
www.ppc-online.com
6
A BELDEN BRAND
6
7
Customer Support: 800.800.6652
Drop
Hardware
"B" Drop Wire Clamp
•• Used to support both ends of telephone drop, at strand and building.
•• Suitable for 1-2 pair .200” max. height and .410’ max. width.
•• 6 pair version: .300” max. height and .500" max. width.
•• Stainless steel bailwire on all versions.
•• Special Packages available. Please check with your PPC/Belden Representative.
Part Number Description
Material
Pair
Shim
Type
Inner
Pack
Outer
Pack
23-44441
"B" Drop Wire Clamp
Aluminum
1-2
Serrated
500
23-44444
"B" Drop Wire Clamp
(Bell Packaging)
Aluminum
1-2
Serrated
25
500
23-44445
"B" Drop Wire Clamp
Aluminum
1-2
Serrated
2
250
23-82350
"B" Drop Wire Clamp
Aluminum
6
Dimpled
1
75
23-82351
"B" Drop Wire Clamp
Aluminum
6
Dimpled
25
150
23-88881
"B" Drop Wire Clamp
(Bulk Packaging)
1-2
Serrated
25
500
23-88885
"B" Drop Wire Clamp
Stainless
Steel
Stainless
Steel
1-2
Serrated
2
250
Installation:
1. Lay cable in shell.
2. Place shim on top of cable with raised
embossings against cable.
3. Insert wedge in shell (on top of shim) and pull
to engage. (Small end of wedge should be
initially engaged in track of large end of shell).
4. Place bailwire on “B” drop wire hook (ram’s
horn)with wedge loose. Pull drop wire through
clamp until proper sidewalk/alley clearance is
achieved.
5. Grasp clamp (bailwire still on ram’s horn) and
pull tightly to secure.
www.ppc-online.com
7
A BELDEN BRAND
A BELDEN BRAND
Span Clamps
"Q" Span Clamp
•• Provides drop wire take offs at mid-span.
•• Steel components mechanically galvanized ASTM B695.
27-00185
"Q" Span Clamp
Span Clamp for P3
2700185-LA "Q"
Cable w/Messenger
Material
Clamp
Range
PigTail
Diameter
Inner Outer
Pack Pack
Steel
1/4"-7/16"
1/4"
100
Plates - Aluminum
Pigtail - Steel
很抱歉,暂时无法提供与“31-10809”相匹配的价格&库存,您可以联系我们找货
