34-08850
34-08850
    BELDEN
    PLASTIC SPACER 1/2
34-08850 数据手册
A BELDEN BRAND ® Diamond Construction Hardware Lashed Cable Supports Lashed Cable Supports •• Used to strap coaxial and telephone cable to strand. •• Available in 430 stainless steel or special zinc alloy in 3/4”width. •• Edges are processed to remove raised and projecting metal. Edges are smooth and free from burrs. Part Number Installation: 1. Measure diameter or circumference of bundle. Use table to determine strap length. Length Diameter Bundle Circumference Inner Pack Outer Pack 34-08912 10" 1.2" 3.8" -- 500 34-08921 34-08922 16" 2" 6.3" -- 500 34-08931 34-08932 22" 3" 9.4" -- 300 34-08941 34-08942 28" 4" 12.6" -- 300 34-08951 34-08952 34" 5" 15.7" -- 300 * 34-08956 45" 6.5" 20.4" -- 200 34-08961 * 50" 7.5" 23.6" -- 200 * 34-08972 66" 10.0" 31.4" -- 200 * 3408972-SP 66" 10.0" 31.4" -- 200 Zinc Stainless Steel 34-08911 1 4 2 5 2. Thread strap through spacer slot. 3. Wrap strap around bundle (strand, spacer, cables) then through buckle twice, pulling eachwrap tight. 4. Strap end should be doubled under itself (about 1.5”) before making final pass through buckle. Trim off excess. 5. Bend doubled thickness over top of buckle to prevent unravelling. Note: In cable TV installation, straps should not be too tight as they may restrict cable movement during contraction and expansion and possibly damage cable. 3 * Ask PPC/Belden Representative. www.ppc-online.com 22 A BELDEN BRAND Customer Support: 800.800.6652 Construction Hardware ® Diamond Construction Hardware Lashed Cable Supports Lashed Cable Support Kit •• Used to strap coaxial or telephone cable to strand. •• Kit contains 100 ft. 430 stainless steel strapping and 75 steel buckles. •• Kit makes 75 straps 16” average length. •• Cut to desired length and secure to buckle. Part Number Description 34-00890 3/4" Wide Stainless Steel Strap with 75 Buckles Inner Pack Outer Pack 1 10 Plastic Cable Spacer •• High density outdoor polyethylene with U.V. inhibitors. •• Bell type. •• Provides separation between aerial cable and messenger. Part Number Description Inner Pack Outer Pack 34-08850 1/2" Plastic Spacer 100 1,000 34-08875 3/4" Plastic Spacer 100 1,000 Support Strap •• Reusable support strap with integral buckle made of malleable aluminum fire retardant. Used to bundle telephone, coaxial and fiber cable at the steel strand. •• Safe to use, no sharp edges to cut hands or cables. Customer Support: 800.800.6652 Inner Pack Outer Pack 10" Long, 3/4" Band -- 500 16" Long, 3/4" Band -- 500 Part Number Description SC05-1 SC06-1 www.ppc-online.com 23 A BELDEN BRAND A BELDEN BRAND ® Diamond Construction Hardware Clamps Lashing Clamps •• Used to secure lashing wire terminations. •• Mechanically galvanized ASTM B695. •• 1/4” - 7/16” clamp range. 26-09010 26-09020 Inner Pack Outer Pack Lashing Clamp -- 100 26-09010 "D" Lashing Clamp -- 100 26-09010NS "D" Lashing Clamp no stakes -- 100 26-09020 "E" Lashing Clamp -- 100 26-09022 "E" Lashing Clamp with 2 Washers, 2 Nuts -- 100 Messenger Size Range Inner Pack Outer Pack Part Number Description SC07-1 Figure 8 Three Bolt Suspension Clamps •• Used to secure Figure 8 cable to pole. •• Center hole accommodates 1/2” or 5/8” diameter machine bolt. •• Clamp plates aluminum alloy. •• Steel bolts mechanically galvanized ASTM B695. •• Eliminates need to strip messenger. Part Number Description 28-09610 Figure 8 Three Bolt Suspension Clamp .109" - .134" -- 25 28-09615 Figure 8 Three Bolt Suspension Clamp .148" - .250" -- 20 Thru Bolt Hole Size Messenger Size Range Inner Pack Outer Pack Figure 8 Tangent Support Clamps •• Used to secure Figure 8 cable to pole. •• Clamp plates and J Hook aluminum alloy. •• Eliminates need to strip messenger. Part Number Description 28-09500 Tangent Support Clamp 5/8" .148"-.250" -- 25 28-09600 Tangent Support Clamp 1/2" .109"-.134" -- 25 28-19651 Tangent Support Clamp 5/8" .109"-.134" -- 25 www.ppc-online.com 24 A BELDEN BRAND Customer Support: 800.800.6652 Construction Hardware ® Diamond Construction Hardware Hangers, Brackets, Hooks Fiber Optic Rack Hanger •• Secures F.O. storage devices (snow shoes) to strand. •• For 1/4” - 7/16” strand. •• Aluminum bracket. •• Steel ASTM B695 clamp plates. Part Number Description 29-19945 Fiber Optic Rack Hanger Inner Pack Outer Pack -- 25 Dead-End Bracket •• Dead-end bracket used to apply tension to steel strand building riser and to provide a means to dead-end a guy strand. •• Mechanically galvanized ASTM B695. •• 1,000 lb. load capacity. Part Number Description SC44-1 5/16" Diameter Hook with 2-3/4" Tension Adjustment Inner Pack Outer Pack -- 25 Inner Pack Outer Pack Drive Hooks •• Used to support bail-type drop wire clamps to poles. •• Galvanized to ASTM A153 or B695. •• Fetter drive threads. Part Number Description 40-43007 7/16" Diameter x 4-3/4" Long -- 100 40-43008 5/16" Diameter x 3-1/2" Long -- 200 Inner Pack Outer Pack -- 100 Square Washer •• Supports bolt head or nut of machine bolt. •• Mechanically galvanized ASTM B695. Customer Support: 800.800.6652 Part Number Description 28-03004 5/8" Bolt Size x 2-1/4" Square x 3/16" Thickness www.ppc-online.com 25 A BELDEN BRAND A BELDEN BRAND ® Diamond Construction Hardware Tap Brackets Tap Brackets 29-19941 •• Used to secure tap to strand. •• One piece steel snap-on version mechanically galvanized ASTM B695 for 1/4” strand only. •• Aluminum standard tap bracket & extension bracket. Both have 1/4” to 3/8” strand clamping range. •• Square hole in standard aluminum tap bracket mounts Diamond trap sleeve brackets (“W”brackets). 29-19943 29-19944 29-50044 Clearance Between Strand & Tap Load Capacity (lbs) (Minimal Deflection) Inner Pack Outer Pack Steel Snap-on Tap Bracket 2-1/2" 40 -- 25 29-19943 Aluminum Tap Bracket (Standard) 2-1/2" 30 -- 25 29-19944 Aluminum Extension Bracket 3" to 9" 25 -- 25 29-50044 Strand Clamp -- -- -- 75 Part Number Description 29-19941 Tap Bracket with Common Ground •• Tap bracket used to secure a tap to the steel strand and provide a means to bond up to eight messengered drop cables. •• Firm and positive grip with no rotation or sliding on steel strand. •• Mechanically galvanized ASTM B695. Part Number Description SC23CGS-4 4" Horizontal Mounting with 8 Common Grounds Inner Pack Outer Pack -- 32 Inner Pack Outer Pack Tap Bracket - Vertical Mount •• Tap bracket used to secure a tap to the steel strand. •• Firm and positive grip with no rotation or sliding on steel strand. •• Stopper at multi-tap attachment prevents part rotation. •• Mechanically galvanized ASTM B695. Part Number Description SC23PV-2 2" Vertical Mount (Figure 8 Application) -- 32 SC23PV-4 4" Vertical Mount (Figure 8 Application) -- 32 www.ppc-online.com 26 A BELDEN BRAND Customer Support: 800.800.6652 Construction Hardware ® Diamond Construction Hardware Tap Brackets, Support Brackets Tap Bracket - Horizontal Mount •• Tap bracket used to secure a tap to the steel strand. •• Firm and positive grip with no rotation or sliding on steel strand. •• Stopper at multi-tap attachment. •• Mechanically galvanized ASTM B695. Inner Pack Outer Pack 2" Horizontal Mount -- 32 SC23PS-3 3" Horizontal Mount -- 32 SC23PS-4 4" Horizontal Mount -- 32 SC23PS4-C 4" Horizontal Mount - Canada -- 32 Inner Pack Outer Pack -- 32 Part Number Description SC23PS-2 Strand Hanger Support Bracket •• Used in mid-span or next to tap application. •• In high risk theft areas, makes it more difficult to tamper with the traps. •• Support up to 4 trap shields (up to 16 traps). •• Mechanically galvanized ASTM B695. •• Can also be supplied with a coated top shield aluminum bracket. Customer Support: 800.800.6652 Part Number Description SC73-1F Strand Hanger Support Bracket www.ppc-online.com 27 A BELDEN BRAND Construction Hardware A BELDEN BRAND ® Diamond Construction Hardware Aerial Cable Damper Aerial Cable Damper •• Aluminum alloy. •• Designed to use the force of wind to aerodynamically reduce oscillation of cable. •• Supplied with special heavy duty lashed cable supports and “D” lashing clamps to secure to strand. •• Assembly instructions provided. Part Number Description 28-80001 Aerial Cable Damper Inner Pack Outer Pack -- 5 Installation: 1. Select proper size cable guard for application. 2. Place guard on cable over horizontal slots in Aerial Cable Damper (ACD). 3. Insert lashed cable supports through horizontal slots. Use two wraps and secure by bending end over top of buckle. Allow 1/4” clearance between cable and top of the ACD. The ACD must be allowed to swing free with the wind. 4. Position lashing clamps inside lashed cable supports and secure. Lashing clamps will restrict longitudinal movement to cable area protected by cable guards. 5. Placement – The number of ACDs varies with the length of cable span and terrain. The following is recommended as a guide for maximum effectiveness. Level Ground – Locate at span’s center for 125-170 ft. spans (Fig. 1). On spans 170-300 ft., locate two ACDs, each one-fourth the total span length from either pole. (Fig. 2) Steep Grade – Locate one-tenth total span length from pole at lower level on 125-170 ft. spans. (Fig 3). On spans 170-300 ft., two ACDs are required. Locate one at one-fourth the total span length from lower pole. Locate second ACD halfway between first ACD and uphill pole. (Fig. 4). Note: When installing on Fig. 8 cable: 1. ACD should be secured to exposed strand. 2. ACD will have limited dampening effective in extreme high wind conditions. www.ppc-online.com 28 A BELDEN BRAND Customer Support: 800.800.6652
34-08850 价格&库存
很抱歉,暂时无法提供与“34-08850”相匹配的价格&库存,您可以联系我们找货
