Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
35618 Hook-up/Lead - UL AWM Style 3173 - XL-DUR®
For more Information
please call
1-800-Belden1
General Description:
The insulation is cross-linked polyethylene applied in a single extrusion. This construction has excellent
thermal aging characteristics, moisture resistance, and solvent resistance. The 356-series of XL-DUR is
recommended for class 130(B)as motor leads
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
18
16x30
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Min. Avg. Wall (in.)
XLPE - Cross Linked Polyethylene 0.030
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.109 in.
Mechanical Characteristics (Overall)
Bulk Cable Weight:
10 lbs/1000 ft.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
600 V, 125°C
CSA Rating:
600 V, 125°C
CSA Type:
CL1251
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
07/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
6.000
Max. Operating Voltage - UL:
Voltage
600 Vrms
Max. Recommended Current:
Description
Current
Single conductor in free air @ ambient 30C 22 amps
Page 1 of 2
08-26-2016
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
35618 0015000
5,000 FT
50.000 LB
BROWN
CIUZ
#18STR XLPE 125C 600VBRN
35618 002500
500 FT
5.500 LB
RED
F
#18 STR XLPE 125C 600V
35618 0025000
5,000 FT
50.000 LB
RED
CIUZ
#18STR XLPE 125C 600VRED
35618 0035000
5,000 FT
50.000 LB
ORANGE
CIUZ
#18STR XLPE 125C 600VORG
35618 004500
500 FT
5.500 LB
YELLOW
F
35618 0045000
5,000 FT
50.000 LB
YELLOW
CIUZ
#18STR XLPE 125C 600VYEL
35618 0055000
5,000 FT
50.000 LB
GREEN, DARK
CIUZ
#18STRXLPE 125C 600VDGRN
35618 0065000
5,000 FT
50.000 LB
BLUE, LIGHT
CIUZ
#18STRXLPE 125C 600VLBLU
35618 0075000
5,000 FT
50.000 LB
VIOLET
CIUZ
#18STR XLPE 125C 600VVIO
35618 0085000
5,000 FT
50.000 LB
GRAY
CIUZ
#18STR XLPE 125C 600VGRY
35618 0095000
5,000 FT
50.000 LB
WHITE
CIUZ
#18STR XLPE 125C 600VWHT
35618 010500
500 FT
5.500 LB
BLACK
F
35618 0105000
5,000 FT
50.000 LB
BLACK
CIUZ
#18STR XLPE 125C 600VBLK
35618 0125000
5,000 FT
50.000 LB
PINK
CIUZ
#18STR XLPE 125C 600VPNK
35618 0135000
5,000 FT
50.000 LB
BLUE, DARK
CIUZ
#18STRXLPE 125C 600VDBLU
Notes:
C = CRATE REEL PUT-UP.
F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50'
I = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 200'
U = TOPCOAT ADDERS ON STOCK SOLID COLORS. MINIMUM ORDER 10000' PER COLORCOMBINATION. (SEE TOPCOAT ADDER TABLE)
Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN.
Revision Number: 1
Revision Date: 05-13-2013
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“35618 0035000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+5.367215000+0.69440
