Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
37116 Hook-up/Lead - UL AWM Style 3340 and 3374
For more Information
please call
1-800-Belden1
General Description:
EPDM high temperature lead wire. 150C EPDM wire is recommended for Class 130(B) , 155(F) and also
in some 180(H) systems. It^s UL Recognized under Style 3374 as 150C-600V Appliance Wiring Material.
The CSA Listing, as a coil lead, is 125C, 600V.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
16
26x30
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
EPDM - Ethylene Propylene Diene Monomer Rubber .045
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.154 in.
Mechanical Characteristics (Overall)
UL Temperature Rating:
125°C (UL AWM Style 3340), 125°C (UL AWM Style 3374), 150°C
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL AWM Style:
UL Style 3340 (600 V 125°C), UL Style 3374 (600 V 125°C)
UL Rating:
600 V, 150°C
CSA Rating:
600 V, 125°C
CSA Type:
CL1254
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Max. Operating Voltage - UL:
Voltage
600 V RMS (UL AWM Style 3340)
600 V RMS (UL AWM Style 3374)
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
37116 002500
500 FT
9.500 LB
RED
F
#16 STR EPDM 150C 600V
37116 004500
500 FT
9.500 LB
YELLOW
F
Page 1 of 2
01-05-2017
37116 005500
500 FT
9.500 LB
GREEN, DARK
F
#16STREPDM 150C 600VDGRN
37116 0104000
4,000 FT
72.000 LB
BLACK
CI
#16STR EPDM 150C 600V
37116 010500
500 FT
9.500 LB
BLACK
F
37116 0105000
5,000 FT
90.000 LB
BLACK
M
#16 STR EPDM BLK
37116 013500
500 FT
9.500 LB
BLUE, DARK
F
Notes:
C = CRATE REEL PUT-UP.
F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50'
I = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 200'
M = FINAL PUT-UP LENGTH MAY VARY -10% TO +0% FROM LENGTH SHOWN.
Revision Number: 1
Revision Date: 08-02-2012
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 2 of 2
01-05-2017
很抱歉,暂时无法提供与“37116 002500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 152+23.66128152+3.06230
- 304+22.17700304+2.87020
