39118 0051000
39118 0051000
    BELDEN
    HOOK-UP 18AWG STR DGRN
39118 0051000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 39118 Hook-up/Lead - PPO Hook-up Wire 600V, 105°C AWM Style 11028 For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (16x30) tinned copper conductor, PPO insulation. Rated 105ºC, 600V. Rated 2500V peak for electronic circuits, and internal wiring of electronic and electrical equipment Usage (Overall) Suitable Applications: Electrical panel builders, Electrical/electronic manufacturers, Appliance manufacturers, Furniture, Computer manufacturers, Automotive companies and their sub-suppliers Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 18 16x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PPO - Polyphenylene Oxide 0.012 Overall Insulation Overall Cable Overall Nominal Diameter: 0.069 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +105°C Dry Bulk Cable Weight: 6 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 600 V, 105°C UL Type: AWM 11028 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2011 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.500 Max. Operating Voltage - UL: Voltage Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 39118 Hook-up/Lead - PPO Hook-up Wire 600V, 105°C AWM Style 11028 600 Vac Max. Recommended Current: Description Current Single conductor in free air @ 30C ambient 20 amps Notes (Overall) Notes: Halogen-free. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 39118 001100 100 FT 0.700 LB BROWN C #18 STR PPO BRN 39118 0011000 1,000 FT 7.000 LB BROWN C #18 STR PPO BRN 39118 0015000 5,000 FT 30.000 LB BROWN CZ #18 STR PPO BRN 39118 002100 100 FT 0.700 LB RED C #18 STR PPO RED 39118 0021000 1,000 FT 7.000 LB RED C #18 STR PPO RED 39118 0025000 5,000 FT 300.000 LB RED CZ #18 STR PPO RED 39118 003100 1,000 FT 7.000 LB ORANGE C #18 STR PPO ORG 39118 0031000 1,000 FT 7.000 LB ORANGE C #18 STR PPO ORG 39118 0035000 5,000 FT 30.000 LB ORANGE CZ #18 STR PPO ORG 39118 004100 100 FT 0.700 LB YELLOW C #18 STR PPO YEL 39118 0041000 1,000 FT 7.000 LB YELLOW C #18 STR PPO YEL 39118 0045000 5,000 FT 30.000 LB YELLOW CZ #18 STR PPO YEL 39118 005100 100 FT 0.700 LB GREEN, DARK C #18 STR PPO DGRN 39118 0051000 1,000 FT 7.000 LB GREEN, DARK C #18 STR PPO DGRN 39118 0055000 5,000 FT 30.000 LB GREEN, DARK CZ #18 STR PPO DGRN 39118 007100 100 FT 0.700 LB VIOLET C #18 STR PPO VIO 39118 0071000 1,000 FT 7.000 LB VIOLET C #18 STR PPO VIO 39118 0075000 5,000 FT 30.000 LB VIOLET CZ #18 STR PPO VIO 39118 008100 100 FT 0.700 LB GRAY C #18 STR PPO GRY 39118 0081000 1,000 FT 7.000 LB GRAY C #18 STR PPO GRY 39118 0085000 5,000 FT 30.000 LB GRAY CZ #18 STR PPO GRY 39118 009100 100 FT 0.700 LB WHITE C #18 STR PPO WHT 39118 0091000 1,000 FT 7.000 LB WHITE C #18 STR PPO WHT 39118 0095000 5,000 FT 300.000 LB WHITE CZ #18 STR PPO WHT 39118 010100 100 FT 0.700 LB BLACK C #18 STR PPO BLK 39118 0101000 1,000 FT 7.000 LB BLACK C #18 STR PPO BLK 39118 0105000 5,000 FT 30.000 LB BLACK CZ #18 STR PPO BLK 39118 013100 100 FT 0.700 LB BLUE, DARK C #18 STR PPO DBLU 39118 0131000 1,000 FT 7.000 LB BLUE, DARK C #18 STR PPO DBLU 39118 0135000 5,000 FT 300.000 LB BLUE, DARK CZ #18 STR PPO DBLU 39118 189100 100 FT 0.700 LB GREEN/YELLOW 39118 1891000 1,000 FT 7.000 LB GREEN/YELLOW 39118 1895000 5,000 FT 30.000 LB GREEN/YELLOW #18 STR PPO GRN/YEL #18 STR PPO GRN/YEL CZ #18 STR PPO GRN/YEL Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 0 Revision Date: 07-19-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
39118 0051000 价格&库存
很抱歉,暂时无法提供与“39118 0051000”相匹配的价格&库存,您可以联系我们找货
