73809W 0081000
73809W 0081000
    BELDEN
    CBL 9COND 18AWG
73809W 0081000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 73809W Multi-Conductor - 600V Unshielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (16x30) bare copper conductors, PVC insulation, oil-resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 8 18 16x30 BC - Bare Copper Total Number of Conductors: 9 Ground Wire Ground Wire (Y/N): Y Ground Wire AWG: 18 Ground Wire Stranding: 16x30 Ground Wire Conductor Material: BC - Bare Copper Ground Wire Insulation Material: PVC - Polyvinyl Chloride Insulation Insulation Material: Insulation Material Wall Thickness (mm) PVC - Polyvinyl Chloride 0.559 Insulation Color Code Chart: Color Description Black Individually Numbered Yellow/Green Ground Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.889 Overall Cable Overall Nominal Diameter: 11.303 mm Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +90°C Installation Temperature Range: Flexing: -5°C To +90°C Bulk Cable Weight: 446.460 Kg/Km Max. Recommended Pulling Tension: 502.647 N Min. Bend Radius/Minor Axis: 55.880 mm Min. Bend/Installation: 55.880 mm Min. Bend Radius (Continuous Flexing): 55.880 mm Flex Cycle Rating: 1 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 2587 (600 V 90°C) CSA Specification: 600 V AWM I/II A/B EU Directive 2011/65/EU (ROHS II): Yes MII Order #39 (China RoHS): Yes Other Specification: VDE 0472, Section 803 Oil Test, EU Low Voltage Directive 2014/35/EC, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California Proposition 65 Page 1 of 2 10-02-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 73809W Multi-Conductor - 600V Unshielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles Flame Test CSA Flame Test: FT1 Suitability Suitability - Burial: Yes Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/m) 0.623 Max. Capacitance Conductor to Conductor: Freq. (MHz) Capacitance (pF/m) 0.001 101.711 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 21.983 Max. Operating Voltage - UL: Voltage 600V Put Ups and Colors: Item # Putup Ship Weight Color 73809W 008100 100 FT 35.500 LB GRAY Notes Item Desc 18AWG 19/30 9C UNSHIELDED 73809W 0081000 1,000 FT 302.000 LB GRAY 18AWG 19/30 9C UNSHIELDED Revision Number: 0 Revision Date: 09-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 10-02-2017
73809W 0081000 价格&库存
很抱歉,暂时无法提供与“73809W 0081000”相匹配的价格&库存,您可以联系我们找货
