74004E
74004E
    BELDEN
    74004E
74004E 数据手册
Industrial Ethernet Cables S/FTP Cat 7 – 4 Pair A range of shielded copper cables for use in Industrial Ethernet networks, designed to withstand the entire spectrum of environmental and mechanical hazards, from temperature extremes and sunlight, to solvents, oils, chemicals and moisture. Ordering Information Belden European Item Numbers Jacket Material PVC Premium FRNC PUR (Halogen Free) Performance Cat 7 Cat 7 Cat 7 Number of Pairs 4 Pairs 4 Pairs 4 Pairs Stationary Application 74004E 74004NH 74004PU Flexible Application 74005PU Applications • • • • Industrial environments where IP67 may be required Transmission of data in industrial applications via the ethernet protocol Stationary applications, where there is no movement after installation Flexible applications, subject to occasional movement or vibration after installation Features & Benefits • Choice of PVC, Premium FRNC or PUR cable jacket for specific application requirements in the harsh industrial environment • High shield coverage to maintain signal integrity in the industrial ‘noisy’ environment • Oil resistant • Chemical & solvent resistant • Temperature resistant • Abrasion resistant • Excellent mechanical resistance • Weld-splatter resistant PUR cable jacket available on request • IP67 rated • UV resistant • Black cable jacket Construction & Dimensions Mechanical Data – Stationary Application Conductor (23AWG/1 – Solid Bare Copper) Individually Foil Shielded Pairs, Foam-Skin PE Insulation - Pair 1 = White / Blue - Pair 2 = White / Orange - Pair 3 = White / Green - Pair 4 = White / Brown Braid Shield – Tinned Copper Conductor Insulation (Nom. Dia.) Braid Coverage Sheath Material Sheath (Nom. Dia.) Sheath Colour 74004E 23AWG/1 1.45mm >65% PVC 8.00mm Black 74004NH 23AWG/1 1.45mm >65% FRNC 8.00mm Black 74004PU 23AWG/1 1.45mm >65% PUR 8.00mm Black Part Number Mechanical Data – Flexible Application Conductor (26AWG/7 – 7x0.16mm Stranded Copper) Individually Foil Shielded Pairs, Foam-Skin PE Insulation - Pair 1 = White / Blue - Pair 2 = White / Orange - Pair 3 = White / Green - Pair 4 = White / Brown Braid Shield – Tinned Copper Part Number 74005PU Conductor Insulation (Nom. Dia.) Braid Coverage Sheath Material Sheath (Nom. Dia.) Dia.) Sheath Colour 26AWG/7 1.05 (=/-0.05mm) >65% PUR 6.80mm Black 2 Standards • ISO/IEC 11801 Cat7 • EN 50173-1 • TIA/EIA-568-B.2 Electrical Properties 450V A.C. / 300V D.C. 100 +/- 15 Ohm Max Operating Voltage UL Impedance @ 1 – 600 MHz 74004E / 74004NH/ 74004PU (AWG24) Frequency (MHz) 1 4 10 16 20 31.25 62.5 100 200 300 600 Insertion Loss (Max) (dB/100m) 2.1 3.7 5.9 7.4 8.3 10.4 14.9 19.0 24.0 31.0 50.1 NEXT (dB) 80.0 80.0 80.0 80.0 80.0 80.0 PSNEXT (dB) 77.0 77.0 77.0 77.0 77.0 77.0 75.1 72.1 67.9 65.3 60.8 72.1 69.4 64.9 62.3 57.8 NEXT (dB) 80.0 80.0 80.0 80.0 80.0 80.0 PSNEXT (dB) 77.0 77.0 77.0 77.0 77.0 77.0 75.1 72.4 67.9 65.3 60.8 72.1 69.4 64.9 62.3 57.8 ELFEXT (dB/100m) PSELFEXT (dB/100m) RETURN LOSS (dB) 80.0 74.0 69.9 68.0 64.1 58.1 54.0 48.0 44.5 38.4 77.0 71.0 66.9 65.0 61.1 55.1 54.0 45.0 41.5 35.4 23 25 25 25 23.6 21.5 20.1 18.0 17.3 17.3 ELFEXT (dB/100m) PSELFEXT (dB/100m) (dB/100m) RETURN LOSS (dB) 58.0 50.0 46.0 44.0 40.0 34.0 30.0 24.0 20.0 14.0 55.0 47.0 43.0 41.0 37.0 31.0 27.0 21.0 17.0 11.0 23.0 25.0 25.0 25.0 23.6 21.5 20.1 18.0 17.3 17.3 74005 PU (AWG26) Frequency (MHz) 1 4 10 16 20 31.25 62.5 100 200 300 600 Attenuation (Max) (dB/100m) 2.7 5.5 8.5 10.8 12.1 15.2 27.8 27.8 40.1 50.0 73.3 3 Mechanical, Physical and/or Environmental Characteristics Flame Resistance Oil Resistance Bending Radius / Setting Radius Halogen Free Maximum Pulling Tension Temperature Range - Installation Temperature Range - Operating IEC 60332-1 IEC 60332-3-24 Cat C Bundle Flame Test for product 74004NH IEC 60811-2-1 10 x Diameter / 5x Diameter IEC 60754-1 / IEC 60754-2 (FRNC and PUR Cable Jacket) 80N -5 oC to +50 oC -40 oC to +80 oC Version 05 (01/11) 4
74004E 价格&库存
很抱歉,暂时无法提供与“74004E”相匹配的价格&库存,您可以联系我们找货
