74031NH-C500
74031NH-C500
    BELDEN
    BELDEN - 74031NH-C500 - Multicore Cable, Screened, 2 Core, 22 AWG, 1640 ft, 500 m
74031NH-C500 数据手册
Product: 74031NH DataTuff Ind SPE 40mGb 22AWG SO SF/UTP LSZH Product Description DataTuff Ind SPE 40mGb 22AWG SO SF/UTP LSZH Technical Specifications Product Overview Suitable Applications: Mass transit platforms, 1 single pair Ethernet up to 600 MHz Physical Characteristics (Overall) Conductor AWG Stranding 22 Solid Material No. of Pairs BC - Bare Copper 1 Conductor Count: 2 Insulation Material Nominal Diameter PE - Polyethylene (Foam) 1.75 mm Color Chart Color White & Blue Cabling Filler Yes Outer Shield Type Material Tape Polyester Coverage [%] 100% Tape Bi-Laminate (Alum+Poly) 100% Braid Tinned Copper (TC) 80% Outer Jacket Material Nominal Diameter LSZH - Low Smoke Zero Halogen (Flame Retardant) 5.10 mm Construction and Dimensions Min Elongation at Breakof Conductors: 8% Min Elongation at Breakof Jacket: 100 MPa Min Tensile Strength of Jacket: 9 MPa Electrical Characteristics Conductor DCR Max. Conductor DCR Max DCR Unbalanced Between Pairs [%] 54.3 Ohm/km at 20°C 2% Capacitance Max. Capacitance Unbalance 120 pF/100m Dielectric Strength: 2 kVac/1 min Insulation Resistance: 5000 MOhm*km Impedance Nominal Characteristic Impedance 100 Ohm High Frequency Frequency [MHz] Max. Insertion Loss (Attenuation) Min. RL (Return Loss) [dB] Min. TCL [dB] Min. ELTCTL [dB] 1 MHz 2.1 20 dB 40 dB 40 dB 4 MHz 3.7 23 dB 40 dB 28 dB 10 MHz 5.8 25 dB 35 dB 20 dB 20 MHz 8.2 25 dB 30.5 dB 14 dB 30 MHz 10.1 23.76 dB 27.8 dB 10.5 dB 100 MHz 18.5 20.1 dB 20 dB 5 dB 600 MHz 47.1 17.3 dB 8.3 dB 5 dB 1000 MHz Voltage Non-UL Voltage Rating 300 V Temperature Range Operating Temp Range: -30°C To +80°C Mechanical Characteristics Cold Bend Test: No Crack Hygroscopicity: Weight increasing not exceed 1% (for 3hrs) Wicking: The filter paper shall not wet (for 6 hrs) Standards UL AWM Style Compliance: AWM 21307 ISO/IEC Compliance: IEC 61156-11, UL 758 Flammability, LS0H, Toxicity Testing C(UL) Flammability: FT2 IEC 61034-2 - Smoke Density Min. Transmittance: 60 Part Number Variants Item # Color 74031NH 0101000 Black 74031NH-C500 Put-Up Type Length Reel Blue, Light Reel 74031NH 0061000 Blue, Light Reel 1,000 ft 500 m 1,000 ft History Update and Revision: Revision Number: 0.50 Revision Date: 09-09-2021 © 2021 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
74031NH-C500 价格&库存
很抱歉,暂时无法提供与“74031NH-C500”相匹配的价格&库存,您可以联系我们找货
