7731A 0101000
7731A 0101000
    BELDEN
    #14 PE/GIFHDLDPE SH FRPVC
7731A 0101000 数据手册
Part Number: 7731A Serial Digital Coax, RG11, #14 Solid BC, Foil + 95% TC braid, CMR Product Description Low Loss Serial Digital Coax, Riser-CMR, RG11 14 AWG solid bare copper conductor, foam HDPE core, Duofoil, +95% tinned copper braid, PVC jacket Technical Specifications Product Overview Environmental Space: Outdoor - Aerial Suitable Applications: SMPTE 2081-1 6 Gb/s UHDTV, SMPTE 424M 3 Gb/s HD-SDI 1080p Physical Characteristics (Overall) Conductor AWG Stranding 14 Solid Material Nominal Diameter No. of Coax BC - Bare Copper 0.064 in Conductor Count: 1 AWG Size: 14 1 Insulation Material Nominal Diameter Gas-injected FHDPE - Foam High Density Polyethylene 0.28 in Outer Shield Material Type Layer Material Material Trade Name Coverage [%] Tape 1 Aluminum Foil-Polyester Tape-Aluminum Foil Duofoil® 100 % Braid 2 TC - Tinned Copper 95 % Outer Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.4 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR Outer Conductor DCR 2.5 Ohm/1000ft 1.5 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Shield 16 pF/ft Inductance Nominal Inductance 0.097 µH/ft Impedance Nominal Characteristic Impedance 75 Ohm Return Loss (RL) Frequency [MHz] Minimum Return (RL) 1.5 Ohm/1000ft 5-1600 MHz 23 dB 1600-4500 MHz 21 dB 4500-6000 MHz 15 dB High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.16 dB/100ft 3.58 MHz 0.29 dB/100ft 5 MHz 0.34 dB/100ft 7 MHz 0.39 dB/100ft 10 MHz 0.46 dB/100ft 67.5 MHz 1.05 dB/100ft 71.5 MHz 1.09 dB/100ft 88.5 MHz 1.21 dB/100ft 100 MHz 1.28 dB/100ft 135 MHz 1.47 dB/100ft 143 MHz 1.51 dB/100ft 180 MHz 1.69 dB/100ft 270 MHz 1.97 dB/100ft 360 MHz 2.31 dB/100ft 540 MHz 2.87 dB/100ft 720 MHz 3.40 dB/100ft 750 MHz 3.45 dB/100ft 1000 MHz 3.60 dB/100ft 1000 MHz 4.12 dB/100ft 1500 MHz 5.10 dB/100ft 2000 MHz 6.04 dB/100ft 2250 MHz 6.43 dB/100ft 3000 MHz 7.63 dB/100ft 4500 MHz 9.56 dB/100ft 6000 MHz 11.53 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.21 ns/ft 85 % Voltage UL Voltage Rating 300V RMS Electrical Characteristics Notes: TDR Impedance: 75 +/- 3 Ohms Other Electrical Characteristic 2: Return Loss: Fixed bridge and termination Temperature Range UL Temp Rating: 75°C Operating Temp Range: -30°C To +75°C Mechanical Characteristics UV Resistance: Yes Bulk Cable Weight: 87 lbs/1000ft Max Recommended Pulling Tension: 145 lbs Min Bend Radius/Minor Axis: 4 in Standards NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG CPR Euroclass: Eca RG Type: RG-11/U Type Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Aerial: Yes - Black only, when supported by messenger wire Suitability - Burial: No Suitability - Hazardous Locations: No Suitability - Indoor: Yes Suitability - Outdoor: Yes - Black only Flammability, LS0H, Toxicity Testing UL Flammability: UL1666 Vertical Shaft CSA Flammability: FT4 Part Number Plenum (Y/N): No Plenum Number: 7732A Suggested Connectors: King 2065-8-9; Trompeter UPL2000-D5; Canare BCP-C71A; Amphenol 31-4411 Variants Item # Color Footnote 7731A.001220 BLACK 7731A.00152 BLACK 7731A.002000 BLACK 7731A.00305 BLACK 7731A 0101000 BLACK C 7731A 0104000 BLACK C 7731A 010500 BLACK C 7731A.031220 BLUE 7731A.03152 BLUE 7731A.03305 BLUE 7731A 0061000 BLUE, LIGHT 7731A 0064000 BLUE, LIGHT 7731A 0011000 BROWN 7731A 0014000 BROWN 7731A 0081000 GRAY 7731A 0084000 GRAY 7731A.081220 GRAY, SLATE 7731A.08305 GRAY, SLATE 7731A.021220 GREEN 7731A.02305 GREEN C C C 7731A N3U1000 GREEN, MIL C 7731A N3U4000 GREEN, MIL C 7731A 0031000 ORANGE 7731A 0034000 ORANGE 7731A.061220 ORANGE, RAL 2003 7731A.06305 ORANGE, RAL 2003 7731A.051220 PURPLE 7731A.05305 PURPLE 7731A 0021000 RED C 7731A 0024000 RED C 7731A.011220 RED, RAL 3000 7731A.01152 RED, RAL 3000 7731A.01305 RED, RAL 3000 C 7731A 0071000 VIOLET C 7731A 0074000 VIOLET C 7731A.071220 WHITE 7731A.07305 WHITE 7731A 0091000 WHITE 7731A 0094000 WHITE 7731A 0041000 YELLOW 7731A 0044000 YELLOW 7731A.041220 YELLOW, RAL 1021 7731A.04305 YELLOW, RAL 1021 Footnote: C C C - CRATE REEL PUT-UP. Product Notes Notes: Print legend includes sequential footage marks. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
7731A 0101000 价格&库存
很抱歉,暂时无法提供与“7731A 0101000”相匹配的价格&库存,您可以联系我们找货
