7840A 0601000
7840A 0601000
    BELDEN
    12 PRS #22 FRPP FS PVC 1=1000'
7840A 0601000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7840A Multi-Conductor - T1/DS1 Central Office Interconnect/Cross Connect Cable For more Information please call 1-800-Belden1 General Description: 22 AWG solid tinned copper conductors, twisted pairs, flame retardant polyolefin insulation, overall shielded with 100% Beldfoil® shield, 22 AWG solid tinned copper drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (mm) 12 22 Solid TC - Tinned Copper 0.67056 Total Number of Conductors: 24 Insulation Insulation Material: Insulation Material FRPO - Flame Retardant Polyolefin Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 22 Solid TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 12.065 mm Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue/White Stripe 2 White/Orange Stripe & Orange/White Stripe 3 White/Green Stripe & Green/White Stripe 4 White/Brown Stripe & Brown/White Stripe 5 White/Gray Stripe & Gray/White Stripe 6 Red/Blue Stripe & Blue/Red Stripe 7 Red/Orange Stripe & Orange/Red Stripe 8 Red/Green Stripe & Green/Red Stripe 9 Red/Brown Stripe & Brown/Red Stripe 10 Red/Gray Stripe & Gray/Red Stripe 11 Black/Blue Stripe & Blue/Black Stripe 12 Black/Orange Stripe & Orange/Black Stripe Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 172.631 Kg/Km Max. Recommended Pulling Tension: 832.703 N Min. Bend Radius/Minor Axis: 120.650 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: MPR/CMR Page 1 of 3 09-11-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7840A Multi-Conductor - T1/DS1 Central Office Interconnect/Cross Connect Cable CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/13/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Riser Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 100 Nom. Inductance: Inductance (µH/m) 0.68901 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 52.496 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 95.149 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 50.5274 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 11.1554 Nom. Attenuation: Attenuation (dB/100m) 4.3 @ 772 KHz Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 3.5 Amps per conductor @ 20°C Electrical Characteristics-Premise (Overall) Premise Minimum NEXT: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) NEXT (dB) .772 50 Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7840A 0601000 1,000 FT 123.000 LB CHROME C 12 PRS #22 FRPP FS PVC 7840A 0602000 2,000 FT 256.000 LB CHROME C 12 PRS #22 FRPP FS PVC Notes: C = CRATE REEL PUT-UP. Page 2 of 3 09-11-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 7840A Multi-Conductor - T1/DS1 Central Office Interconnect/Cross Connect Cable Revision Number: 0 Revision Date: 09-26-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 09-11-2017
7840A 0601000 价格&库存
很抱歉,暂时无法提供与“7840A 0601000”相匹配的价格&库存,您可以联系我们找货
