7851A F6HA1000
7851A F6HA1000
    BELDEN
    CAT6E+ 4PRB U/UTP CMR RIB
7851A F6HA1000 数据手册
PB296 DataTwist 4800_FNL.qxd:Layout 1 12/17/10 4:11 PM Page 1 Product Bulletin PB 296 Belden ® DataTwist ® 4800 Cables DataTwist 4800 UTP Cables provide significant headroom and robust data transmission performance for today’s most demanding applications. The cables support the industry’s most powerful Category 6 networking solution: Belden IBDN System 4800. Belden’s DataTwist 4800 Cables Exceed TIA/EIA Requirements and Offer Significant Headroom Over Category 6 DataTwist 4800 Cable If your business is looking to the future, and investing in best-in-class technologies is part of your IT strategy, you need the performance and reliability delivered by DataTwist 4800 Cables. These enhanced Category 6 cables were conceived to support the most demanding multi-Gigabit protocols and networking applications. DataTwist 4800 Cables consist of 4 pairs of 23 AWG insulated copper conductors, incorporating a unique central spline which separates and holds the twisted pairs of the cable firmly in position at a uniform distance from each other. This design provides improved Power Sum Crosstalk performance in comparison to conventional cables where the twisted pairs can nest into each other and change position during manufacturing or handling. The end result is very stable transmission performance that is more resilient to installation variables. Depending on your application requirements, DataTwist 4800 Cables can be specified in either Nonbonded-Pair design or in Belden’s exclusive Bonded-Pair construction. All DataTwist 4800 Cables are designed to provide low Insertion Loss (low signal Attenuation). This characteristic enables increased signal power over a higher range of frequencies. This strong signal translates into maximum headroom and more robust transmission for today’s applications as well as a capacity for those of tomorrow’s networks. The higher signal power of DataTwist 4800 Cables also results in a higher PSACR. With this higher ratio, 4800 Cables are able to provide fewer transmission errors and higher data rate capability. Belden DataTwist 4800 Cables are part of the Belden IBDN 4800 System. The Belden 4800 System provides 300 MHz of channel bandwidth and a data rate of 4.8 Gb/s, giving you a high performance system to support today’s demanding network applications as well as the evolving bandwidth hungry applications of tomorrow. PB296 DataTwist 4800_FNL.qxd:Layout 1 12/17/10 4:11 PM Page 2 Belden DataTwist 4800 Cables Help Future-Proof the Network Applications • Available in CMR, CMP and LSZH versions DataTwist 4800 Cable is intended to be used for horizontal cable installations of high speed Local Area Networks (LANs) for transmission speeds up to 4.8 Gb/s. • Available in Bonded-Pair or Specific applications include: • 1000BASE-T Applications (IEEE 802.3ab) The Belden IBDN 4800 Solution delivers unparalleled performance with 300 MHz of channel bandwidth and a maximum data rate of 4.8 Gb/s. • Power Over Ethernet Plus – 2 pairs, up to 30 Watts or 4 pairs, up to 60 Watts (IEEE 802.3at) • Power Over Ethernet – 2 pairs, up to 12.95 Watts (IEEE 802.3af) • Broadband Video (CATV) & High Speed Internet (DOCSIS) over UTP up to 860 MHz • High Temperature performance up to 50°C without length de-rating for 1000BASE-T and 100BASE-TX • High Noise Immunity with a Noise Reduction Factor of 0.5 (TIA 569B) • VoIP Applications with stringent Bit Error Rate (BER) / Quality of Service (QoS) objectives Features & Benefits • Central spline design separates pairs and maintains stable pair position, thus improving NEXT and impedance performance • Stable pair position provides built-in resilience to installation stresses • Improved attenuation ensures stronger signal power • Maximized bandwidth and signal-to-noise margin for mission-critical applications • Larger 23 AWG conductors are ideal for PoE and PoE+ applications • Descending distance marking for cable length reduces waste • Matching tip and ring color code for ease of installation • Available in Spool-in-Box packaging for ease of installation, handling and inventory management Nonbonded-Pair design Technical Specifications* Physical Characteristics • Conductors: 23 AWG solid copper • Insulation - Plenum: Bonded-Pair: 100% FEP Nonbonded-Pair: Dual Insulation FEP over a Polyolefin base - Riser and LSZH: Polyolefin • Cable Core: Filler, Four twisted pairs, cabled around Belden's patented cross-web or E-spline • Jacket with Rip Cord: - Plenum: LSPVC - Riser: PVC - LSZH: Low Smoke Zero Halogen Polymer Alloy - Jacket printed at intervals indicating cable code, AWG, listings (NEC Code), verification, date, manufacturing traceability code - Descending length markings start at highest number and end at 0 Mechanical Characteristics • Minimum Recommended Installation Temperature: 5°C (40°F) • Temperature Rating: 75°C (167°F) Transmission Characteristics • Values up to 600 MHz are minimum guaranteed values (400 MHz for NonbondedPair) • Values above 600 MHz are for engineering purposes only (400 MHz for Nonbonded-Pair) • DC Resistance @ 20°C: - Bonded-Pair: 8.2 ohms/100 m - Nonbonded-Pair: 6.6 ohms/100 m • DC Resistance Unbalance, max.: 3% • Mutual Capacitance, nom.: 5.1 nF/100 m • Capacitance Unbalance Pair to Ground, max.: 66pF/100 m 2 PB296 DataTwist 4800_FNL.qxd:Layout 1 12/17/10 • Input Impedance: Input Impedance 100±12 100±15 100±20 100±22 Bonded-Pair Nonbonded-Pair 1-20 MHz 20-250 MHz 250-350 MHz 350-600 MHz — 1-200 MHz — 200-400 MHz • Nominal Velocity of Propagation (NVP): - Plenum: 70% @ 10 MHz - Riser: 68% @ 10 MHz • Propagation Delay (Skew): 30 ns/100 m 4:11 PM Page 3 resistance unbalance results in the cabling infrastructure being less susceptible to electromagnetic and radio frequency interference (EMI/RFI) in noisy environments. Belden’s ultra-robust Bonded-Pair cables can provide additional peace of mind, especially when deployed in: • Mission-critical data centers • Frequently changing networking environments where constant moves, adds and changes are routine • Environments where electromagnetic and Qualifications • Category 6 requirements per TIA/EIA-568-B.2-1, ISO/IEC 11801 ed 2.1 (2008) Class E • Riser: ITS/ETL Certified as CMR, and listed as NEC Type CMR per UL Standard 444 • Plenum: ITS/ETL Certified as CMP, and listed as NEC Type CMP per UL Standard 444 • LSZH: ISO/IEC 332-1, 754-2 and 1034-2 * Values are the same for Bonded-Pair and Nonbonded-Pair Cables, unless specifically noted. Select Bonded-Pair or Nonbonded-Pair Construction Belden provides the option of ordering DataTwist 4800 Cables in either Bonded-Pair or in Nonbonded-Pair constructions. The choice will depend on the type of signals supported, the critical nature of the information transmitted, and the stability of the networking environment. Belden’s Bonded-Pair Cables feature a patented design in which the individual conductors are securely bonded along their longitudinal axis to guarantee uniform spacing within each twisted pair – a key factor in maintaining consistently high electrical performance. Because Belden’s Bonded-Pair Cables have better centricity and symmetry, they provide improved return loss and balance performance. Superior transverse conversion loss (TCL), capacitance unbalance and radio frequency interference (EMI/RFI) create noise and signal transmission problems • High frequency applications in which Nonbonded-pair return loss can affect signal integrity In stable networking environments, Belden’s standard DataTwist 4800 Cables will perform reliably to exceed TIA/EIA Category 6 standards. When the application calls for a more robust solution, Belden Bonded-Pair DataTwist 4800 Cables will provide superior integrity and electrical performance from the reel to real life – through all the stresses of installation and post-installation maintenance. Belden calls this unique capability Installable Performance®. Bonded-Pair Installed and manipulated nonbonded-pairs (left) have a tendency to gap, varying the centricity of the two conductors. Belden Bonded-Pairs (right) do not gap so the physical integrity of the pair is maintained. Visit www.belden.com to learn more about Belden’s Bonded-Pair construction and its unique benefits. Key Physical Attributes — DataTwist 4800 Bonded-Pair Cable 4-pair, 23 AWG Bonded-Pair Nominal O.D. Min. Bend Radius Weight (Cable Only) CMR (7851A) 5.766 x 8.001 mm (0.227 x 0.315 in.) 5.537 x 7.366 mm (0.218 x 0.290 in.) 6.121 x 8.357 mm (0.241 x 0.329 in.) 6.35 mm (0.25 in.) 6.35 mm (0.25 in.) 6.35 mm (0.25 in.) 46.47 kg/km (31.3 lb/kft) 50.18 kg/km (33.8 lb/kft) 46.47 kg/km (31.3 lb/kft) CMP (7852A) LSZH (7851NH) Key Physical Attributes — DataTwist 4800 Nonbonded-Pair Cable 4-pair, 23 AWG Nonbonded-Pair Nominal O.D. Min. Bend Radius Weight (Cable Only) CMR (4812) 6.22 mm (0.245 in.) 6.09 mm (0.240 in.) 24.88 mm (0.98 in.) 23.37 mm (0.92 in.) 50.47 kg/km (34.0 lb/kft) 54.93 kg/km (37.0 lb/kft) CMP (4813) 4824 LSZH version available upon request 3 PB296 DataTwist 4800_FNL.qxd:Layout 1 12/17/10 4:11 PM Page 4 Technical Specifications (continued) Key Electrical Attributes — DataTwist 4800 Bonded-Pair Cable Frequency (MHz) 1 4 8 10 16 20 25 31.25 62.5 100 200 250 300 350 400 450 500 550 600 650 750 860 Max. Insertion Loss (dB/100 m) Min. PSNEXT (dB) Min. PSACR (dB) THE BONDED-PAIR ADVANTAGE Min. PSACRF (dB) Min. Return Loss (dB)* TIA Belden TIA Belden TIA Belden TIA Belden TIA 2.0 3.8 5.3 6.0 7.6 8.5 9.5 10.7 15.4 19.8 29.0 32.8 - 1.9 3.6 5.1 5.7 7.2 8.1 9.1 10.2 14.7 18.9 27.5 31.2 34.5 37.7 40.6 43.5 46.2 48.8 51.4 53.9 58.6 63.6 72.3 63.3 58.8 57.3 54.2 52.8 51.3 49.9 45.4 42.3 37.8 36.3 - 80.3 71.3 66.8 65.3 62.3 60.8 59.3 57.9 53.4 50.3 45.8 44.3 41.2 40.2 39.3 38.5 37.8 37.2 36.6 36.1 35.2 34.3 70.3 59.5 53.5 51.3 46.6 44.3 41.8 39.2 30.0 22.5 8.8 3.5 - 78.5 67.7 61.7 59.6 55.0 52.7 50.3 47.7 38.7 31.4 18.3 13.2 8.6 4.5 0.6 0.0 - 64.8 52.8 46.7 44.8 40.7 38.8 36.8 34.9 28.9 24.8 18.8 16.8 - 70.8 58.8 52.7 50.8 46.7 44.8 42.8 40.9 34.9 30.8 24.8 22.8 21.3 19.9 18.8 17.7 16.8 16.0 15.2 14.5 13.3 12.1 20.0 23.0 24.5 25.0 25.0 25.0 24.3 23.6 21.5 20.1 18.0 17.3 - Belden 20.0 23.0 24.5 25.0 25.0 25.0 25.0 25.0 25.0 25.0 21.6 20.5 20.1 19.8 19.5 18.9 18.4 18.0 17.6 17.2 16.5 15.8 Min. Balance TCL (dB)* Min. Balance ELTCTL (dB)* TIA Belden TIA 40.0 40.0 40.0 40.0 38.0 37.0 36.0 35.1 32.0 30.0 27.0 26.0 - 45.0 45.0 45.0 45.0 43.0 42.0 41.0 40.1 37.0 35.0 32.0 31.0 - 35.0 23.0 16.9 15.0 10.9 9.0 7.0 - Belden 40.0 28.0 21.9 20.0 15.9 14.0 12.0 - Values above 600 MHz for engineering purposes only. * Belden’s Bonded-Pair Cables provide improved return loss and balance performance. Key Electrical Attributes — DataTwist 4800 Nonbonded-Pair Cable Frequency (MHz) 1 4 8 10 16 20 25 31.25 62.5 100 200 250 300 350 400 450 500 550 600 650 750 860 Max. Insertion Loss (dB/100 m) Min. PSNEXT (dB) Min. PSACR (dB) Min. PSACRF (dB) Min. Return Loss (dB) Min. Balance TCL (dB) TIA Belden TIA Belden TIA Belden TIA Belden TIA Belden TIA Belden 2.0 3.8 5.3 6.0 7.6 8.5 9.5 10.7 15.4 19.8 29.0 32.8 - 1.8 3.4 4.8 5.3 6.8 7.6 8.5 9.6 13.8 17.8 26.2 29.7 33.0 36.0 39.0 41.8 44.5 47.1 49.6 52.1 56.8 61.8 72.3 63.3 58.8 57.3 54.2 52.8 51.3 49.9 45.4 42.3 37.8 36.3 - 78.3 69.3 64.8 63.3 60.2 58.8 57.3 55.9 51.4 48.3 43.8 42.3 41.1 40.1 39.3 38.5 37.8 37.2 36.6 36.1 35.2 34.3 70.3 59.5 53.4 51.3 46.7 44.3 41.8 39.2 30.0 22.5 8.8 3.5 - 76.5 65.9 60.0 58.0 53.5 51.2 48.8 46.3 37.6 30.5 17.6 12.6 8.2 4.1 0.3 - 64.8 52.8 46.7 44.8 40.7 38.8 36.8 34.9 28.9 24.8 18.8 16.8 - 71.8 59.8 53.7 51.8 47.7 45.8 43.8 41.9 35.9 31.8 25.8 23.8 22.3 20.9 19.8 18.7 17.8 17.0 16.2 15.5 14.3 13.1 20.0 23.0 24.5 25.0 25.0 25.0 24.3 23.6 21.5 20.1 18.0 17.3 - 20.0 23.0 24.5 25.0 25.0 25.0 24.6 24.2 22.9 22.1 20.9 20.4 19.6 19.3 19.0 18.4 17.9 17.5 17.1 16.7 16.0 15.3 40.0 40.0 40.0 40.0 38.0 37.0 36.0 35.1 32.0 30.0 27.0 26.0 - 40.0 40.0 40.0 40.0 38.0 37.0 36.0 35.1 32.0 30.0 27.0 26.0 - Min. Balance ELTCTL (dB) TIA Belden 35.0 23.0 16.9 15.0 10.9 9.0 7.0 - 35.0 23.0 16.9 15.0 10.9 9.0 7.0 - Values above 400 MHz for engineering purposes only. 4 PB296 DataTwist 4800_FNL.qxd:Layout 1 12/17/10 4:11 PM Page 5 Ordering Information DataTwist 4800 Bonded-Pair, 4-pair, 23 AWG, CMR, Category 6 Belden Part Number DataTwist 4800 Cables are available in plenum, riser and LSZH versions. 7851A F6HA1000 7851A 002A1000 7851A 003A1000 7851A 004A1000 7851A 005A1000 7851A 006A1000 7851A 009A1000 7851A 010A1000 7851A F6H1000 7851A 0021000 7851A 0031000 7851A 0041000 7851A 0051000 7851A 0061000 7851A 0091000 7851A 0101000 Color Gray Red Orange Yellow Green Blue White Black Gray Red Orange Yellow Green Blue White Black Length 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) Packaging Spool-in-Box Spool-in-Box Spool-in-Box Spool-in-Box Spool-in-Box Spool-in-Box Spool-in-Box Spool-in-Box Spool Spool Spool Spool Spool Spool Spool Spool No. of Packages Per Pallet 18 boxes/pallet 18 boxes/pallet 18 boxes/pallet 18 boxes/pallet 18 boxes/pallet 18 boxes/pallet 18 boxes/pallet 18 boxes/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet Total Length Per Pallet 5490 m (18000 ft) 5490 m (18000 ft) 5490 m (18000 ft) 5490 m (18000 ft) 5490 m (18000 ft) 5490 m (18000 ft) 5490 m (18000 ft) 5490 m (18000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) DataTwist 4800 Bonded-Pair, 4-pair, 23 AWG, CMP, Category 6 Belden Part Number 7852A 004A1000 7852A 005A1000 7852A D15A1000 7852A 008A1000 7852A 009A1000 7852A 0021000 7852A 0041000 7852A 0051000 7852A D151000 7852A 0081000 7852A 0091000 7852A 0101000 Color Yellow Green Blue Gray White Red Yellow Green Blue Gray White Black Length 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) Packaging Spool-in-Box Spool-in-Box Spool-in-Box Spool-in-Box Spool-in-Box Spool Spool Spool Spool Spool Spool Spool No. of Packages Per Pallet 18 boxes/pallet 18 boxes/pallet 18 boxes/pallet 18 boxes/pallet 18 boxes/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet 27 spools/pallet Total Length Per Pallet 5490 m (18000 ft) 5490 m (18000 ft) 5490 m (18000 ft) 5490 m (18000 ft) 5490 m (18000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) 8235 m (27000 ft) DataTwist 4800 Bonded-Pair, 4-pair, 23 AWG, LSZH, Category 6 Belden Part Number 7851NH E4XA1000 7851NH E4X1000 Color Gray Gray Length 305 m (1000 ft) 305 m (1000 ft) Packaging Spool-in-Box Spool No. of Packages Per Pallet 18 boxes/pallet 24 spools/pallet Total Length Per Pallet 5490 m (18000 ft) 7320 m (24000 ft) 5 PB296 DataTwist 4800_FNL.qxd:Layout 1 12/17/10 4:11 PM Page 6 Ordering Information (continued) DataTwist 4800 Nonbonded-Pair, 4-pair, 23 AWG, CMR, Category 6 Belden Part Number Color Length 4812 006A1000 4812 009A1000 4812 0021000 4812 0041000 4812 0051000 4812 0061000 4812 0081000 4812 0091000 4812 0062500 Blue White Red Yellow Green Blue Gray White Blue 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 762 m (2500 ft) Packaging No. of Packages Per Pallet Total Length Per Pallet Spool-in-Box Spool-in-Box Spool Spool Spool Spool Spool Spool Spool 22 boxes/pallet 22 boxes/pallet 36 spools/pallet 36 spools/pallet 36 spools/pallet 36 spools/pallet 36 spools/pallet 36 spools/pallet 15 spools/pallet 6710 m (22000 ft) 6710 m (22000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 11438 m (37500 ft) DataTwist 4800 Nonbonded-Pair, 4-pair, 23 AWG, CMP, Category 6 Belden Part Number 4813 D15A1000 4813 009A1000 4813 0041000 4813 0051000 4813 0081000 4813 0091000 4813 0101000 4813 D151000 4813 0092500 Color Length Blue White Yellow Green Gray White Black Blue White 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 305 m (1000 ft) 762 m (2500 ft) Packaging No. of Packages Per Pallet Total Length Per Pallet Spool-in-Box Spool-in-Box Spool Spool Spool Spool Spool Spool Spool 22 boxes/pallet 22 boxes/pallet 36 spools/pallet 36 spools/pallet 36 spools/pallet 36 spools/pallet 36 spools/pallet 36 spools/pallet 18 spools/pallet 6710 m (22000 ft) 6710 m (22000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 10980 m (36000 ft) 13716 m (45000 ft) 4824 LSZH version available upon request. To learn more about Belden IBDN copper-based structured cabling systems, call 1.800.BELDEN.1 or visit our Website at www.belden.com. Belden Technical Support 1.800.BELDEN.1 © Copyright 2010, Belden Inc. www.belden.com PB296
7851A F6HA1000
1. 物料型号:Belden DataTwist 4800 UTP Cables,支持Belden IBDN System 4800的Category 6网络解决方案。 2. 器件简介:DataTwist 4800 Cables是增强型Category 6电缆,设计用于支持苛刻的多千兆位协议和网络应用。 3. 引脚分配:由4对23 AWG绝缘铜导体组成,采用独特的中央脊柱设计,保持电缆中双绞线对的均匀距离。 4. 参数特性:低插入损耗、高信号功率、高PSACR,提供更稳定的传输性能和更少的传输错误。 5. 功能详解:支持1000BASE-T应用、PoE+、CATV、高速互联网、高温性能和高抗噪声性。 6. 应用信息:适用于高速局域网的横向电缆安装,传输速度高达4.8 Gb/s。 7. 封装信息:提供多种版本,包括CMR、CMP和LSZH,以及Bonded-Pair或Nonbonded-Pair设计。
7851A F6HA1000 价格&库存
很抱歉,暂时无法提供与“7851A F6HA1000”相匹配的价格&库存,您可以联系我们找货
