Part Number: 7896A
DeviceBus® for ODVA DeviceNet™, (1 pr) 16 AWG (19x29) TC & (1 pr) 18
AWG (19x30) TC, PVC-NYL/FRPP/PVC, Foil+Braid Shld, TC-ER
Product Description
One 16 AWG pair stranded (19x29) tinned copper conductor and one 18 AWG pair stranded (19x30) tinned copper conductors, PVC/Nylon insulation (power),
F-R Polypropylene insulation (data), individual foil shield (100% coverage) plus an overall tinned copper braid shield (65% coverage), oil- and UV-resistant
PVC jacket.
Technical Specifications
Physical Characteristics (Overall)
Conductor
AWG Stranding
Material
No. of Pairs
16
19x29
TC - Tinned Copper 1
18
19x30
Conductor Count:
4
AWG Size:
16
Insulation
Element
Material
Nominal Diameter
16
PVC/Nylon - Polyvinyl Chloride/Nylon
18
FRPP - Flame Retardant Polypropylene 0.182 in
0.101 in
Color Chart
Number
Color
1 (16 AWG) Red & Black
2 (18 AWG) Blue & White
Inner Shield Material
Type
Material
Material Trade Name Coverage [%] Drainwire Material
Tape Aluminum Foil-Polyester Tape Beldfoil®
100 %
Outer Shield Material
Type
Material
Coverage [%] Drainwire Construction n x D
Braid TC - Tinned Copper 65 %
19x29 mm
Outer Jacket Material
Material
Nominal Diameter Nominal Wall Thickness
PVC - Polyvinyl Chloride 0.525 in
0.06 in
Construction and Dimensions
Stranding
Lay Length
1 MHz
Electrical Characteristics
Conductor DCR
Element Nominal Conductor DCR Nominal Outer Shield DCR
16 AWG 4.9 Ohm/1000ft
18 AWG 6.9 Ohm/1000ft
1.8 Ohm/1000ft
Drainwire AWG
TC - Tinned Copper 16
Capacitance
Element
Nom. Capacitance Conductor to Conductor
18 AWG Pair Only
14.7 pF/ft
Impedance
Nominal Characteristic Impedance
100 Ohm
120 Ohm
Delay
Max. Delay Max. Delay Description Nominal Delay Nominal Velocity of Propagation (VP) [%] Nominal Velocity of Propagation (VP) Description
1.6 ns/ft
18 AWG Pair Only
18 AWG Pair Only
1.6 ns/ft
64 %
High Freq
Element
Frequency [MHz] Max./Min. Input Impedance (unFitted)
18 AWG Pair Only 0.125 MHz
120 Ohm
0.5 MHz
Current
Element Max. Recommended Current [A]
15 AWG 8.0 Amps per conductor at 25°C
Voltage
UL Voltage Rating
600V RMS
Temperature Range
Installation Temp Range:
-25°C To +75°C
UL Temp Rating:
75°C
Operating Temp Range:
-40°C To +75°C
Mechanical Characteristics
Oil Resistance:
Yes
Bulk Cable Weight:
135 lbs/1000ft
Max Recommended Pulling Tension:
190 lbs
Min Bend Radius/Minor Axis:
5 in
Standards
NEC/(UL) Specification:
TC-ER
CSA AWM Specification:
AWM I/II A/B
Other Specification:
ODVA Cable V
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive 2015/863/EU:
Yes
EU Directive Compliance:
EU Directive 2003/11/EC (BFR)
EU CE Mark:
Yes
EU RoHS Compliance Date (yyyy-mm-dd): 2005-10-13
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Suitability
Suitability - Oil Resistance:
Yes
Suitability - Sunlight Resistance:
Yes
Flammability, LS0H, Toxicity Testing
UL Flammability:
UL1685 UL Loading
CSA Flammability:
FT1
Part Number
Plenum (Y/N):
No
Variants
Item #
Color
Footnote
7896A T5U1000 GRAY T5U C
7896A T5U2000 GRAY T5U C
7896A T5U500
GRAY T5U C
Footnote:
C - CRATE REEL PUT-UP.
Product Notes
Notes:
Meter marks on jacket to aid users in installation. ODVA DeviceNet is an Open DeviceNet Vendor Association, Inc. trademark.
© 2018 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's
inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product
itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
很抱歉,暂时无法提供与“7896A T5U1000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 305+217.95704305+28.32910
- 610+190.74501610+24.79220
