83552 0021000
83552 0021000
    BELDEN
    CBL 2COND 22AWG SHLD
83552 0021000 数据手册
Part Number: 83552 Control/Instrumentation, (2) 22 AWG (7x30) TC, FEP/FEP, Foil+TC Braid Shld, CMP Product Description Two 22 AWG stranded (7x30) tinned copper conductors, plenum, Teflon® (FEP) insulation, overall Beldfoil® shield (100% coverage) plus tinned copper braid shield (85% coverage), Teflon® (FEP) jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 22 7x30 Material No. of Conductors TC - Tinned Copper 2 Conductor Count: 2 Total Number of Pairs: 1 AWG Size: 22 Insulation Material Nominal Wall Thickness FEP - Fluorinated Ethylene Propylene 0.0065 in Color Chart Number Color 1 Black 2 White Outer Shield Material Type Layer Material Material Trade Name Coverage [%] Tape 1 Aluminum Foil-Polyester Tape Beldfoil® 100 % Braid 2 TC - Tinned Copper 85 % Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness FEP - Fluorinated Ethylene Propylene 0.141 in 0.014 in Construction and Dimensions Cabling Lay Length 1.5 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 14.5 Ohm/1000ft 7.5 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield 35 pF/ft Current 63 pF/ft Max. Recommended Current [A] 2.75 Amps per conductor @ 25°C Voltage UL Voltage Rating 300V RMS Temperature Range Operating Temp Range: -70°C To +200°C Mechanical Characteristics Bulk Cable Weight: 16 lbs/1000ft Max Recommended Pulling Tension: 19 lbs Min Bend Radius/Minor Axis: 1.5 in Standards NEC Articles: 800 NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flammability, LS0H, Toxicity Testing UL Flammability: NFPA 262 CSA Flammability: FT6 Part Number Plenum (Y/N): Yes Variants Item # Color Footnote 83552 0021000 RED C 83552 002500 C RED Footnote: C - CRATE REEL PUT-UP. Product Notes Notes: Plenum Cables, except for Flamarrest« jacket, are suitable for Outdoor and Direct Burial application. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
83552 0021000 价格&库存
很抱歉,暂时无法提供与“83552 0021000”相匹配的价格&库存,您可以联系我们找货
