8402 001500
8402 001500
    BELDEN
    2 #20 EPDM BRD CSM
8402 001500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8402 Multi-Conductor - Two-Conductor, Low-Impedance Cable For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (26x34) high-conductivity TC conductors, EPDM rubber insulation, rayon braid, TC braid shield (85% coverage), cotton wrap, CSPE - Chlorosulphonated Polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 2 20 26x34 Dia. (in.) High Conductivity TC - Tinned Copper .083 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Dia. (in.) EPDM - Ethylene Propylene Diene Monomer Rubber 0.083 Inner Shield Inner Shield Separator Material: Cotton Wrap Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Braid Rayon 2 Braid TC - Tinned Copper 85 Outer Shield Separator Material: Cotton Wrap Outer Jacket Outer Jacket Material: Outer Jacket Material CSPE - Chlorosulphonated Polyethylene Overall Cable Overall Cabling Color Code Chart: Number Color 1 White 2 Black Overall Nominal Diameter: 0.263 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 50 lbs/1000 ft. Max. Recommended Pulling Tension: 98 lbs. Min. Bend Radius/Minor Axis: 2.630 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8402 Multi-Conductor - Two-Conductor, Low-Impedance Cable CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 52 Nom. Inductance: Inductance (µH/ft) .18 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 30 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 55 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10.2 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3 Max. Operating Voltage - Non-UL: Voltage 600 V RMS Max. Recommended Current: Current 4 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color 8402 001U1000 1,000 FT 52.000 LB BROWN 8402 001500 500 FT 27.000 LB BROWN Notes Item Desc 2 #20 EPDM SHLD HPN C 2 #20 EPDM BRD CSM Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 10-02-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
8402 001500 价格&库存
很抱歉,暂时无法提供与“8402 001500”相匹配的价格&库存,您可以联系我们找货
