8404 0601000
8404 0601000
    BELDEN
    BELDEN - 8404 0601000 - SHIELDED MULTICONDUCTOR CABLE, 4 CONDUCTOR, 20AWG, 1000FT, 300V
8404 0601000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8404 Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (19x32) high-conductivity tinned copper conductors, polyethylene insulation, rayon braid, tinned copper braid shield (85% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 4 20 19x32 Dia. (in.) High Conductivity TC - Tinned Copper .037 Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) PE - Polyethylene .016 .069 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 85 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .032 Overall Cable Overall Cabling Color Code Chart: Number Color 1 Clear 2 Black 3 Red 4 Green Overall Cabling Separator Material: Rayon Braid Overall Nominal Diameter: 0.252 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C UL Temperature Rating: 60°C (UL AWM Style 2094) Bulk Cable Weight: 46 lbs/1000 ft. Max. Recommended Pulling Tension: 100 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 2094 (300 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8404 Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 45 Nom. Inductance: Inductance (µH/ft) .2 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 23 Nom. Cap. Between Cond. in a Quad Config.: Capacitance (pF/ft) 49 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10.2 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.23 Max. Operating Voltage - UL: Voltage 300 V RMS (UL AWM Style 2094) Max. Recommended Current: Current 3.1 Amps per conductor @ 25°C Other Electrical Characteristic 1: 2/c 17 AWG equivalent DCR when connected to a 3-pin XLR. Notes (Overall) Notes: Quad connection scheme: The two blue wires (or wires directly opposite one another) are connected together to form one conductor, and similarly the two white wires (or remaining wires) are connected together to form the second conductor. Put Ups and Colors: Item # Putup Ship Weight Color 8404 060U1000 1,000 FT 48.000 LB CHROME Notes Item Desc 8404 060100 100 FT 5.400 LB CHROME 8404 0601000 1,000 FT 49.000 LB CHROME C 4 #20 PE SHLD PVC 8404 060500 500 FT 25.000 LB CHROME C 4 #20 PE SHLD PVC 4 #20 PE SHLD PVC 4 #20 PE SHLD PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 05-14-2007 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8404 Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable Page 3 of 3 01-05-2017
8404 0601000 价格&库存
很抱歉,暂时无法提供与“8404 0601000”相匹配的价格&库存,您可以联系我们找货
    • 1000+38.528781000+4.98473
