84303 0011000
84303 0011000
    BELDEN
    RG303 COAX
84303 0011000 数据手册
Part Number: 84303 50 Ohm Coax, RG303, 19 AWG Solid SCCCS, SCC Braid, FEP Jacket, CL2P Product Description RG-303/U, 19 AWG solid .037" silver-coated copper-covered steel conductor, plenum, TFE insulation, silver-coated copper braid shield (95% coverage), FEP jacket, commercial non-QPL product. Technical Specifications Product Overview Environmental Space: Outdoor - Aerial Physical Characteristics (Overall) Conductor AWG Stranding 19 Solid Material Nominal Diameter No. of Coax SCCCS - Silver-coated Copper-covered Steel 0.037 in Conductor Count: 1 AWG Size: 19 1 Insulation Material Material Trade Name Nominal Diameter TFE - Tetrafluoroethylene Teflon® 0.116 in Outer Shield Material Type Layer Braid 1 Material Coverage [%] SCC - Silver-coated Copper 95 % Outer Jacket Material Material Nominal Diameter FEP - Fluorinated Ethylene Propylene 0.17 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Conductor DCR Conductor Resistance Nominal Outer Shield DCR Outer Conductor DCR 16.3 Ohm/1000ft 16.3 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Shield 29 pF/ft Inductance Nominal Inductance 0.067 µH/ft Impedance Nominal Characteristic Impedance 50 Ohm High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.3 dB/100ft 4.3 Ohm/1000ft 4.3 Ohm/1000ft 10 MHz 1.1 dB/100ft 50 MHz 2.7 dB/100ft 100 MHz 3.9 dB/100ft 200 MHz 5.6 dB/100ft 400 MHz 8.2 dB/100ft 700 MHz 11 dB/100ft 900 MHz 12.5 dB/100ft 1000 MHz 13.5 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.46 ns/ft 69.5 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) 50 MHz 2.7 dB/100ft 400 MHz 8.6 dB/100ft 1000 MHz 15 dB/100ft 3000 MHz 28 dB/100ft Voltage Description UL Voltage Rating MIL 150 V RMS Voltage Rating [V] 1400 V RMS (Mil Spec) VSWR Frequency [MHz] Max. VSWR 50 MHz - 1000 MHz per M17/111-RG303 Temperature Range UL Temp Rating: 200°C Operating Temp Range: -70°C To +200°C Mechanical Characteristics Bulk Cable Weight: 30 lbs/1000ft Max Recommended Pulling Tension: 112 lbs Min Bend Radius/Minor Axis: 2 in Standards NEC/(UL) Specification: CL2P RG Type: RG-303/U Military Specification: Commercial, non-QPL product (M17/111-RG303) QPL (Qualified Parts List): No Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/11/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: No EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Aerial: Yes - When supported by messenger wire Suitability - Burial: No Suitability - Hazardous Locations: No Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Sunlight Resistance: No Flammability, LS0H, Toxicity Testing UL Flammability: NFPA 262 CSA Flammability: FT6 Part Number Plenum (Y/N): Yes Footnote: C - CRATE REEL PUT-UP. Footnote: E - MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25'. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
84303 0011000 价格&库存
很抱歉,暂时无法提供与“84303 0011000”相匹配的价格&库存,您可以联系我们找货
