8471.00305
8471.00305
    BELDEN
    BELDEN - 8471.00305 - Multipair Cable, Audio Control, CPR Euroclass Eca, Unscreened, 1 Pair, 16 AWG,...
8471.00305 数据手册
Part Number: 8471 Audio/Control/Instrumentation, (1 pr) 16 AWG (19x29) TC, PVC/PVC, CMG Product Description One 16 AWG pair stranded (19x29) tinned copper conductors, twisted pair, PVC insulation, PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 16 19x29 Material No. of Pairs TC - Tinned Copper 1 Conductor Count: 2 Total Number of Pairs: 1 Conductor Size: 16 AWG Insulation Material Nominal Wall Thickness PVC - Polyvinyl Chloride 0.023 in Color Chart Number 1 Color Black & White Outer Shield Material Material Unshielded Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.274 in 0.032 in Construction and Dimensions Cabling Lay Direction Twists Left Hand 6 twist/ft Electrical Characteristics Conductor DCR Nominal Conductor DCR 4.49 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor 33 pF/ft Shielding: Inductance Nominal Inductance 0.19 µH/ft Unshielded Current Element Max. Recommended Current [A] 10C temperature rise 6.1 Amps per conductor @ 25°C ambient Voltage UL Voltage Rating 300 V RMS Temperature Range UL Temp Rating: 60°C Operating Temp Range: -20°C To +80°C Mechanical Characteristics Bulk Cable Weight: 36 lbs/1000ft Max Recommended Pulling Tension: 61 lbs Min Bend Radius/Minor Axis: 2.75 in Standards NEC Articles: 800, 725 NEC/(UL) Specification: CL3, CMG CEC/C(UL) Specification: CMG UL AWM Style: UL Style 2598 (300 V 60°C) CPR Euroclass: Eca Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1685 FT4 Loading CSA Flammability: FT4 UL voltage rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Part Number Variants Item # Color Footnote 8471.00305 Chrome 8471.00U152 Chrome 8471.00U305 Chrome 8471.01152 Chrome 8471 0601000 Chrome C 8471 060500 Chrome C 8471 0605000 Chrome 8471 060U1000 Chrome 8471 060U500 Chrome Footnote: C - CRATE REEL PUT-UP. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
8471.00305 价格&库存
很抱歉,暂时无法提供与“8471.00305”相匹配的价格&库存,您可以联系我们找货
  • 1+48.076061+6.02290
  • 50+38.1541750+4.77990
  • 100+33.91482100+4.24880
  • 305+29.94607305+3.75160
库存:682
