Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
8502 Hook-up/Lead - (Type B) MIL-W-16878/1-PVC
For more Information
please call
1-800-Belden1
General Description:
Tinned copper conductor, PVC insulation. Covers insulated wire for internal wiring of meters, panels, and
electrical or electronic equipment. Temperatures to 105ºC.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
7x28
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
PVC - Polyvinyl Chloride .010
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.058 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +105°C
Bulk Cable Weight:
4.500 lbs/1000 ft.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2006
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Military Specification:
MIL-W-16878/1
MIL Spec Rating:
600 V, 105°C
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
9.500
Max. Operating Voltage - Other:
Voltage
Description
600 Vrms Mil-W-16878/1
Max. Recommended Current:
Description
Current
Single conductor in free air @ 30C ambient. 14 amps
Put Ups and Colors:
Page 1 of 2
08-26-2016
Item #
Putup
Ship Weight
Color
8502 001100
100 FT
0.500 LB
BROWN
Notes
Item Desc
8502 0011000
1,000 FT
5.000 LB
BROWN
8502 002100
100 FT
0.500 LB
RED
8502 0021000
1,000 FT
5.000 LB
RED
8502 003100
100 FT
0.500 LB
ORANGE
8502 0031000
1,000 FT
5.000 LB
ORANGE
8502 004100
100 FT
0.500 LB
YELLOW
8502 0041000
1,000 FT
5.000 LB
YELLOW
8502 005100
100 FT
0.500 LB
GREEN, DARK
8502 0051000
1,000 FT
5.000 LB
GREEN, DARK
8502 006100
100 FT
0.500 LB
BLUE, LIGHT
8502 0061000
1,000 FT
5.000 LB
BLUE, LIGHT
8502 007100
100 FT
0.500 LB
VIOLET
8502 0071000
1,000 FT
5.000 LB
VIOLET
8502 008100
100 FT
0.500 LB
GRAY
8502 0081000
1,000 FT
5.000 LB
GRAY
8502 009100
100 FT
0.500 LB
WHITE
8502 0091000
1,000 FT
5.000 LB
WHITE
8502 010100
100 FT
0.500 LB
BLACK
8502 0101000
1,000 FT
5.000 LB
BLACK
P
20 STR PVC BLK
8502 0151000
1,000 FT
5.000 LB
WHITE/RED
A
20 STR PVC WHT/RED
8502 0181000
1,000 FT
5.000 LB
WHITE/BLUE
A
20 STR PVC WHT/BLU
20 STR PVC BRN
P
20 STR PVC BRN
20 STR PVC RED
P
20 STR PVC RED
20 STR PVC ORG
P
20 STR PVC ORG
20 STR PVC YEL
P
20 STR PVC YEL
20 STR PVC GRN
P
20 STR PVC GRN
20 STR PVC LBLU
P
20 STR PVC LT.BLU
20 STR PVC VIO
P
20 STR PVC VIO
20 STR PVC GRY
P
20 STR PVC GRY
20 STR PVC WHT
P
20 STR PVC WHT
20 STR PVC BLK
Notes:
A = STOCKED STRIPE COLORS.
P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE
SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL
Revision Number: 2
Revision Date: 11-07-2014
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“8502 0011000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 305+8.66594305+1.11870
- 610+7.61553610+0.98310
