8527 0021000
8527 0021000
    BELDEN
    HOOK-UP 12AWG STR RED
8527 0021000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8527 Hook-up/Lead - (Type MW) MIL-W-76C-PVC For more Information please call 1-800-Belden1 General Description: Tinned copper, PVC insulation, medium wall. The extruded PVC insulation is flame and ozone resistant. Inert to most chemicals, oils, and solvents. Covers single cond., PVC insulated hook-up wire for internal wiring of electrical and electronic equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 12 65x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .021 Overall Insulation Overall Cable Overall Nominal Diameter: 0.128 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-W-76C MIL Spec Rating: 1000 V, 80°C Plenum/Non-Plenum Plenum (Y/N): No Put Ups and Colors: Item # Putup Ship Weight Color 8527 002100 100 FT 3.100 LB RED 8527 0021000 1,000 FT 25.000 LB RED 8527 003100 100 FT 3.100 LB ORANGE 8527 0031000 1,000 FT 25.000 LB ORANGE P 12 STR PVC ORG 8527 0041000 1,000 FT 25.000 LB YELLOW P 12 STR PVC YEL 8527 005100 100 FT 3.100 LB GREEN, DARK 8527 0051000 1,000 FT 25.000 LB GREEN, DARK 8527 006100 100 FT 3.100 LB BLUE, LIGHT 8527 0061000 1,000 FT 25.000 LB BLUE, LIGHT P 12 STR PVC LBLU 8527 0081000 1,000 FT 25.000 LB GRAY P 12 STR PVC GRY 8527 009100 100 FT 3.100 LB WHITE 8527 0091000 1,000 FT 25.000 LB WHITE 8527 010100 100 FT 3.100 LB BLACK Page 1 of 2 Notes Item Desc 12 STR PVC RED P 12 STR PVC RED 12 STR PVC ORG 12 STR PVC GRN P 12 STR PVC GRN 12 STR PVC LBLU 12 STR PVC WHT P 12 STR PVC WHT 12 STR PVC BLK 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8527 Hook-up/Lead - (Type MW) MIL-W-76C-PVC 8527 0101000 1,000 FT 25.000 LB BLACK CP 12 STR PVC BLK Notes: C = CRATE REEL PUT-UP. P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 1 Revision Date: 05-14-2007 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
8527 0021000 价格&库存
很抱歉,暂时无法提供与“8527 0021000”相匹配的价格&库存,您可以联系我们找货
