8770.01305
    BELDEN
    BELDEN - 8770.01305 - Multicore Cable, Screened, 3 Core, 18 AWG
8770.01305 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8770 Multi-Conductor - Audio, Control and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (16x30) tinned copper conductors, conductors cabled, polyethylene insulation, overall Beldfoil® shield (100% coverage), 20 AWG stranded tinned copper drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 3 18 16x30 TC - Tinned Copper Total Number of Conductors: 3 Insulation Insulation Material: Insulation Material Wall Thickness (mm) PE - Polyethylene 0.4572 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Coverage (%) Beldfoil® (w/ shorting fold) Tape Aluminum Foil-Polyester Tape w/Shorting Fold 100.000 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 20 Stranded TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.8382 Overall Cable Overall Cabling Lay Length & Direction: Length (mm) Direction Twists (twist/m) 68.580 Left Hand 14.436 Overall Cabling Color Code Chart: Number Color 1 Black 2 Red 3 Clear Overall Nominal Diameter: 6.248 mm Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C UL Temperature Rating: 60°C (UL AWM Style 2093) Bulk Cable Weight: 53.575 Kg/Km Max. Recommended Pulling Tension: 329.167 N Min. Bend Radius/Minor Axis: 63.500 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM NEC Articles: 800 CEC/C(UL) Specification: CM AWM Specification: UL Style 2093 (300 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 3 07-21-2016 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8770 Multi-Conductor - Audio, Control and Instrumentation Cable EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading CSA Flame Test: FT1 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 88770 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 69 Nom. Inductance: Inductance (µH/m) 0.591 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 78.744 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/m) 157.488 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 21.6546 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 27.8885 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current 10C temperature rise 5.3 Amps per conductor @ 25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color 8770 060U1000 1,000 FT 37.000 LB CHROME Notes Item Desc 8770 060U500 500 FT 19.000 LB CHROME 8770 0601000 1,000 FT 39.000 LB CHROME C 3 #18 LDPE FS PVC 8770 06010000 10,000 FT 420.000 LB CHROME CY 3 #18 LDPE FS PVC 8770 06010001 10,000 FT 420.000 LB CHROME CZ 3 #18 LDPE SH PVC 8770 06012000 12,000 FT 492.000 LB CHROME CY 3 #18 LDPE SH PVC 8770 060500 500 FT 20.000 LB CHROME C 3 #18 LDPE FS PVC 8770 0605000 5,000 FT 190.000 LB CHROME 3 #18 LDPE FS PVC 3 #18 LDPE FS PVC 3 #18 LDPE FS PVC Notes: C = CRATE REEL PUT-UP. Y = FINAL PUT-UP LENGTH MAY VARY -10% TO +20% FROM LENGTH SHOWN.MAY CONTAIN 2 PIECES. MINIMUM LENGTH OF ANY ONE PIECE IS 1500'. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Page 2 of 3 07-21-2016 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8770 Multi-Conductor - Audio, Control and Instrumentation Cable Revision Number: 3 Revision Date: 08-02-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 07-21-2016
8770.01305 价格&库存
很抱歉,暂时无法提供与“8770.01305”相匹配的价格&库存,您可以联系我们找货
