9688 0101000
    BELDEN
    2PR#22FRFPE FRPE BRD PVC
9688 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9688 Multi-Conductor - Type 1A For more Information please call 1-800-Belden1 General Description: IBM Type 1A, 22 AWG solid BC conductors, non-plenum, flame-retardant foam polyethylene insulation, each pair individually Beldfoil® shield (65% coverage), rip cord, PVC jacket. Usage (Overall) Suitable Applications: Token Ring 4 & 16 Mbps, FDDI over Copper, and video Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 22 Solid BC - Bare Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material FRFPE - Flame Retardant Foam Polyethylene Insulation Resistance: > 16000 Megaohms Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 65 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.296 x 0.431 in. Pair Pair Color Code Chart: Number Color 1 Black & Orange 2 Red & Green Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C Bulk Cable Weight: 48 lbs/1000 ft. Max. Recommended Pulling Tension: 83 lbs. Min. Bend Radius/Minor Axis: 4.500 in. Min. Bend/Installation: 4.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG, MPG CEC/C(UL) Specification: CMG Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9688 Multi-Conductor - Type 1A EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: IEEE802.5 Token Ring EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: Verified IBM Type 1A Customer Part Number Reference Specification: IBM P/N: 4716748, 33G2772 Flame Test UL Flame Test: UL1685 FT4 Loading CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 82688 Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 150 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 8.5 Maximum Capacitance Unbalance (pF/100 m): 100 Nominal Velocity of Propagation: VP (%) 78 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 16.7 Max. Attenuation: Freq. (MHz) Attenuation (dB/100 m) 4 2.2 16 4.4 31.25 6.9 62.5 9.8 100 12.3 200 17.4 300 21.4 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.3 Amps per conductor @ 25°C Common Mode Attenuation: Freq. (MHz) Attenuation (dB/100 m) 62.5 10.6 100 13.4 200 19.0 300 23.3 400 26.9 550 31.5 600 32.9 Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9688 Multi-Conductor - Type 1A Electrical Characteristics-Premise (Overall) Premise Minimum NEXT: Freq. (MHz) NEXT (dB) 4 58.0 16 50.4 31.25 46.1 62.5 41.5 100 38.5 200 34.0 300 31.3 Notes (Overall) Notes: IBM qualified Type 1A media cable for use in IBM cabling system. For non-suffix "A" type IBM product, see 1634A Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9688 0101000 1,000 FT 50.000 LB BLACK CZ 2PR#22FRFPE FRPE BRD PVC 9688 0102000 2,000 FT 100.000 LB BLACK CZ 2PR#22FRFPE FRPE BRD PVC 9688 0103600 3,600 FT 190.800 LB BLACK CZ 2PR#22FRFPE FRPE BRD PVC 9688 010500 500 FT 26.500 LB BLACK CZ 2PR#22FRFPE FRPE BRD PVC Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 2 Revision Date: 01-18-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
9688 0101000 价格&库存
很抱歉,暂时无法提供与“9688 0101000”相匹配的价格&库存,您可以联系我们找货
