9767 0601000
9767 0601000
    BELDEN
    37 FS PR #22 HDPE PVC
9767 0601000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9767 Multi-Conductor - CM Rated Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductor, polypropylene insulation, twisted pairs individually shielded with Beldfoil® (100% coverage), overall PVC jacket and 22 AWG stranded TC drain wire. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 37 22 7x30 TC - Tinned Copper .030 Total Number of Conductors: 74 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PP - Polypropylene 0.011 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® (Z-Fold®) Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 22 Inner Shield Drain Wire Stranding: Stranded Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.069 Overall Cable Overall Nominal Diameter: 0.800 in. Pair Pair Color Code Chart: Number Color 1 Black & Red 2 Black & White 3 Black & Green 4 Black & Blue 5 Black & Yellow 6 Black & Brown 7 Black & Orange 8 Red & White 9 Red & Green 10 Red & Blue 11 Red & Yellow 12 Red & Brown 13 Red & Orange 14 Green & White 15 Green & Blue 16 Green & Yellow Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9767 Multi-Conductor - CM Rated Cable 17 Green & Brown 18 Green & Orange 19 White & Blue 20 White & Yellow 21 White & Brown 22 White & Orange 23 Blue & Yellow 24 Blue & Brown 25 Blue & Orange 26 Brown & Yellow 27 Brown & Orange 28 Orange & Yellow 29 Purple & Orange 30 Purple & Red 31 Purple & White 32 Purple & Green 33 Purple & Blue 34 Purple & Yellow 35 Purple & Brown 36 Purple & Black 37 Gray & White Pair Lay Length & Direction: Lay Length (in.) Twists (twist/ft) 1.750 6.850 Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 2919) Bulk Cable Weight: 393 lbs/1000 ft. Max. Recommended Pulling Tension: 368 lbs. Min. Bend Radius/Minor Axis: 8 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CM AWM Specification: UL Style 2919 (30 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) 0.18 Nom. Capacitance Conductor to Conductor: Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9767 Multi-Conductor - CM Rated Cable Capacitance (pF/ft) 30 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 55 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 10.600 Ohm/1000 ft Max. Operating Voltage - UL: Voltage Description 30 V RMS UL AWM Style 2919 300 V RMS CM Max. Recommended Current: Current 1 Amp per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9767 0601000 1,000 FT 458.000 LB CHROME CD 37 FS PR #22 HDPE PVC 9767 060500 500 FT 212.500 LB CHROME CD 37 FS PR #22 HDPE PVC Notes: C = CRATE REEL PUT-UP. D = FINAL PUT-UP LENGTH MAY VARY -0% TO +20% FROM LENGTH SHOWN. Revision Number: 2 Revision Date: 09-17-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9767 0601000 价格&库存
很抱歉,暂时无法提供与“9767 0601000”相匹配的价格&库存,您可以联系我们找货
