9L28009 008H300
9L28009 008H300
    BELDEN
    CBL RIBN 9COND 28AWG
9L28009 008H300 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9L28009 Flat - Gray Ribbon 9L280XX Series For more Information please call 1-800-Belden1 General Description: Belden^s .050" pitch gray ribbon cable was designed for general purpose electronic interconnect applications. The cable provides reliable mass-termination to standard IDC connectors. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 9 28 7x36 TC - Tinned Copper Total Number of Conductors: 9 Conductor Spacing Center to Center: .050 +/- .002 Conductor Spacing Outside Center to Outside Center: .40 +/- .008 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .010 Insulation Resistance: >10,000 Megaohms Outer Shield Outer Shield Material: Outer Shield Material Unshielded Overall Cable Overall Nominal Thickness: .035 +/- .003 Overall Nominal Width: .45 +/- .006 Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +105°C Bulk Cable Weight: 10 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 105°C, 300 V RMS, VW-1 CSA Rating: 105°C, 300 V RMS, FT1 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 CSA Flame Test: FT1 Plenum/Non-Plenum Plenum (Y/N): No Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9L28009 Flat - Gray Ribbon 9L280XX Series Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Characteristic Impedance: Description Impedance (Ohm) (GS) 150 (GSG) 105 Nom. Inductance: Description Inductance (µH/ft) @ 1 MHz (GS) .29 @ 1 MHz (GSG) .20 Nom. Capacitance Conductor to Conductor: Description Capacitance (pF/ft) @ 1 kHz (GSG) 18 @ 1 MHz (GS) 10 @ 1 MHz (GSG) 15 Nominal Velocity of Propagation: Description VP (%) 72 Nominal Delay: Delay (ns/ft) 1.40 NS/FT. (GSG) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 68.2 OHMS/1000 FT. MAX. Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 10 2.8 20 4.8 30 6.5 40 8.3 50 9.8 60 12 70 13 80 14 90 15.8 100 17 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 1 Amp per conductor @ 20°C Dielectric Withstand Voltage: 2, 000 V RMS Typical Unbalanced Crosstalk: Description Pulse Rise Time (NS) (MHz) Near End % (MHz) Far End % (MHz) 10 ft. sample length 3 4.8 7 10 ft. sample length 5 3.5 4.7 10 ft. sample length 7 3 3 Notes (Overall) Notes: GSG=Ground-Signal-Ground Mode Polarity Identification (Overall) Polarity Identification: RED POLARITY STRIPE ON #1 CONDUCTOR Put Ups and Colors: Item # Putup Ship Weight Color 9L28009 008H100 100 FT 1.100 LB GRAY Notes 9 #28 STR PVC RIBBON (SMI 80) 9L28009 008H300 300 FT 4.200 LB GRAY 9 #28 STR PVC RIBBON Page 2 of 3 Item Desc 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9L28009 Flat - Gray Ribbon 9L280XX Series Revision Number: 2 Revision Date: 09-14-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
9L28009 008H300 价格&库存
很抱歉,暂时无法提供与“9L28009 008H300”相匹配的价格&库存,您可以联系我们找货
