Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
9R28040 Flat - Rainbow 9R280XX Series
For more Information
please call
1-800-Belden1
General Description:
Belden^s .050" pitch, color-coded PVC flat cable allows for quick identification and circuit tracing, along
with easy breakouts for circuit routing, and is designed for mass-termination with standard IDC connectors.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
40
28
7x36
TC - Tinned Copper
Total Number of Conductors:
40
Conductor Spacing Center to Center:
.050
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.010
Insulation Resistance:
>10,000 Mega Ohms
Insulation Color Code Chart:
Number
Color
1
Brown
2
Red
3
Orange
4
Yellow
5
Green
6
Blue
7
Purple
8
Gray
9
White
10
Black
Over 10 conductors Repeat as required
Outer Shield
Outer Shield Material:
Unshielded
Outer Jacket
Outer Jacket Material:
Clear PVC
Overall Cable
Overall Nominal Thickness:
.036
Overall Nominal Width:
2.00
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +105°C
Bulk Cable Weight:
44 lbs/1000 ft.
Min. Bend Radius/Minor Axis:
0.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
AWM 20932
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
Page 1 of 3
08-26-2016
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
10/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
VW-1
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Description Impedance (Ohm)
(GS)
150
(GSG)
105
Nom. Inductance:
Description
Inductance (µH/ft)
@ 1 MHz (GS)
.29
@ 1 MHz (GSG) .20
Nom. Capacitance Conductor to Conductor:
Description
Capacitance (pF/ft)
@ 1 kHz (GSG) 18
@ 1 MHz (GS)
10
@ 1 MHz (GSG) 15
Nominal Velocity of Propagation:
Description VP (%)
72
Nominal Delay:
Delay (ns/ft)
1.40 NS/FT. (GSG)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
68.2 OHMS/1000 FT. MAX.
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
10
2.8
30
6.5
40
8.3
50
9.8
60
12
70
13
80
14
90
15.8
100
17
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Current
1 Amp per conductor @ 20°C
Dielectric Withstand Voltage:
2,000 V RMS
Typical Unbalanced Crosstalk:
Description
Pulse Rise Time (NS) (MHz) Near End % (MHz) Far End % (MHz)
10 ft. sample length 3
4.8
7
10 ft. sample length 5
3.5
4.7
10 ft. sample length 7
3
3
Page 2 of 3
08-26-2016
Notes (Overall)
Notes: GS=Ground-Signal Mode; GSG=Ground-Signal-Ground Mode
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
9R28040 000100
100 FT
4.800 LB
NONE
Revision Number: 3
Notes
Item Desc
40 #28 PVC RAINBOW
Revision Date: 10-02-2012
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
08-26-2016
很抱歉,暂时无法提供与“9R28040 000100”相匹配的价格&库存,您可以联系我们找货
