AX103253
AX103253
    BELDEN
    CAT6+ KCONN PATCH PANEL 24-P
AX103253 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX103253 Faceplates and Panels - CAT6+ Patch Panel - KeyConnect For more Information please call 1-800-Belden1 General Description: CAT6+ KeyConnect Patch Panel, 24-port, 1U, Black Usage (Overall) Suitable Applications: IBDN System 4800, 3600, 2400, TIA Category 6, ISO Class E, 1000BASE-T Related Parts: CAT6+ Modular Cords Physical Characteristics (Connectivity) Capacity Max. Capacity: 24 connectors ( Patch Panel is already loaded ) Access Front Connection: Flush Termination Area: Rear Dimensions Dimensions: Height (in.) Width (in.) Depth (in.) 1.750 19.000 1.300 Materials Materials: Description Material Panel Steel Color Color: Black Weight Weight: 1.350 lbs. Included Parts Included Parts: 4 Screws (10x32); 4 Screws (12x24); 1 Label Holder; 1 Printable LabelFlex Half-Sheet; 2 Velcro Straps; 2 Rear Cable Management Bracket, 1 Installation Guide, 1 kit Termination Bar Packaging Packaging: Individually packaged in a cardboard box. Mechanical Characteristics (Connectivity) Footprint/Type: KeyConnect Plug / Jack Compatibility: RJ45 Termination Interface: Termination Connection Durabilities Front Mated Connection 750 Cycle Rear IDC Connection 10 Insertions Termination Characteristics: Termination Characteristic Universal T568A/B Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Tool Compatibility: Gigaflex Connecting Tool (AX100749) Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes Page 1 of 3 07-31-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX103253 Faceplates and Panels - CAT6+ Patch Panel - KeyConnect EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/30/2008 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: Category 6 - TIA 568.B.2-1, ISO/IEC 11801:2002 Ed.2 Third Party Performance Verification: ETL - Verified Category 6 Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes Transmission Characteristics (Connectivity) Mated Connection Table 1: Max. Min. Min. Min. Min. Frequency Max. Insertion Loss Insertion Loss NEXT NEXT FEXT FEXT (MHz) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) 1.000 0.100 0.100 75.000 77.000 75.000 77.000 4.000 0.100 0.100 75.000 77.000 71.100 75.100 8.000 0.100 0.100 75.000 77.000 65.000 69.000 10.000 0.100 0.100 74.000 77.000 63.100 67.100 16.000 0.100 0.100 69.900 72.900 59.000 63.000 20.000 0.100 0.100 68.000 71.000 57.100 61.100 25.000 0.100 0.100 66.000 69.000 55.100 59.100 31.250 0.110 0.100 64.100 67.100 53.200 57.200 62.500 0.160 0.120 58.100 61.100 47.200 51.200 100.000 0.200 0.160 54.000 57.000 43.100 47.100 200.000 0.280 0.240 48.000 51.000 37.100 41.100 250.000 0.320 0.280 46.000 49.000 35.100 39.100 300.000 0.310 44.500 Mated Connection Table - Footnote: 37.600 * TIA-EIA-568-B.2-1 Category 6 Standard. ** Worst-case performance for a CAT6+ mated connection using CAT6+ modular plugs. Mated Connection Table 2: Min. Min. Min. Frequency Min. Return Loss Return Loss Balanced TCL Balanced TCL (MHz) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) 1.000 30.000 32.000 40.000 42.000 4.000 30.000 32.000 40.000 42.000 8.000 30.000 32.000 40.000 42.000 10.000 30.000 32.000 40.000 42.000 16.000 30.000 32.000 40.000 42.000 20.000 30.000 32.000 40.000 42.000 25.000 30.000 32.000 40.000 42.000 31.250 30.000 32.000 38.100 42.000 62.500 28.100 32.000 32.100 36.100 100.000 24.000 28.000 28.000 32.000 200.000 18.000 22.000 22.000 26.000 250.000 16.000 20.000 20.000 24.000 300.000 18.500 22.500 Dielectric Strength: 1,000 V RMS @ 60Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Termination Resistance: 2.5 m-Ohm Notes (Overall) Notes: For proper installation refer to Installation Guide PX104691 included with the product or visit our web site at http://www.belden.com Product Family Part Numbers: Description Item Number KeyConnect PP CAT6, 1U24P, Black AX103253 KeyConnect PP CAT6, 2U48P, Black AX103255 KeyConnect UHDPP CAT6, 1U48P, Black AX103263 KeyConnect PP CAT6, 1U24P wt couplers, Black AX104227 KeyConnect PP CAT6, 2U48P wt couplers, Black AX104228 KeyConnect PP CAT6, 1U48P wt couplers, Black AX104591 Page 2 of 3 07-31-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX103253 Faceplates and Panels - CAT6+ Patch Panel - KeyConnect Put Ups and Colors: Item # Putup Ship Weight AX103253 1 EA 2.645 LB Revision Number: 0 Color Notes Item Desc CAT6+ KCONN PATCH PANEL 24-P Revision Date: 11-27-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 07-31-2017
AX103253 价格&库存
很抱歉,暂时无法提供与“AX103253”相匹配的价格&库存,您可以联系我们找货
