CAPFMUL-S1
CAPFMUL-S1
    BELDEN
    CAT6A FIELD PLUG T568A/B LARGE
CAPFMUL-S1 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION CAPFMUL-S1 Modular Connectors - FIELD MOUNT PLUG CAT6A UTP, LARGE AWG 22-24 For more Information please call 1-800-Belden1 General Description: CATEGORY 6A FIELD MOUNT PLUG, 568A/B, UTP, LARGE AWG 22-24 (0.043 - 0.063 IN.) Usage (Overall) Suitable Applications: Up to TIA Category 6A, ISO Class EA, 10Base-TX, 100Base-TX, 1000Base-T, 10GBase-T and IBDN Systems Related Parts: Recommended CAT5E, CAT6 and CAT6A UTP cables (Solid & Stranded). Physical Characteristics (Connectivity) Dimensions Dimensions: Height (in.) Width (in.) Length (in.) 0.650 0.540 1.750 Materials Materials: Description Type Material Connector housing Contact housing Color Polycarbonate - UL94V-0 Black RJ45 Polycarbonate - UL94V-0 Clear Contacts Phosphor Bronze Alloy Plated with 50u inch Gold PCB FR4 UL94V-0 Wiring Scheme Wiring Scheme: T568A and T568B Weight Weight: 0.028 lbs. Included Parts Included Parts: RJ45 Connector, Wire Manager, Installation Guide. Packaging Packaging: Individually packaged in a clear plastic bag. Mechanical Characteristics (Connectivity) Termination Interface: Termination Connection RJ45 Durabilities Mated Connection 750 Cycles Operating Temperature Range: -40°C To +70°C Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2006 Telecommunications Standards: Category 6A - TIA 568.C.2, ISO/IEC 11801:2002 Ed.2 Other Specification: Complies with ANSI/TIA-1096-A Requirements. Flame Test UL Flame Test: UL2043 Air Handling Spaces Suitability Suitability - Indoor: Yes - Indoor Page 1 of 2 03-28-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION CAPFMUL-S1 Modular Connectors - FIELD MOUNT PLUG CAT6A UTP, LARGE AWG 22-24 Suitability - Indoor: Yes - Indoor Transmission Characteristics (Connectivity) Mated Connection Table - Footnote: * Up to Category 6A - TIA 568.C.2 when tested with Recommended CAT6A Cables. Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 10 m-Ohm Notes (Overall) Notes: For additionnal information about this product, refer to Installation Guide PX106201, or visit our web at http//:www.belden.com Notes (Cont'd.): Suitable for Conductors with insulation OD range 0.043~0.063 in. (1,1~1,6 mm) and for Cable OD range 0.21~0.33 in. (5,5~8,5 mm). Product Family Part Number List: Description Part Number CATEGORY 6A FIELD MOUNT PLUG 568A/B, UTP, SMALL CAPFMUS-S1 CATEGORY 6A FIELD MOUNT PLUG 568A/B, UTP, LARGE CAPFMUL-S1 CATEGORY 6A FIELD MOUNT PLUG 568A/B, SHIELDED, SMALL CAPFMFS-S1 CATEGORY 6A FIELD MOUNT PLUG 568A/B, SHIELDED, LARGE CAPFMFL-S1 Put Ups and Colors: Item # Putup Ship Weight CAPFMUL-S1 1 EA 0.028 KG Revision Number: 0 Color Notes Item Desc CAT6A FIELD PLUG T568A/B LARGE Revision Date: 10-12-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 2 03-28-2017
CAPFMUL-S1 价格&库存
很抱歉,暂时无法提供与“CAPFMUL-S1”相匹配的价格&库存,您可以联系我们找货
