EX11
EX11
    BELDEN
    CONNECTOR, DROP, UNIVERSAL RG
EX11 数据手册
DROP PRODUCTS CONNECTORS EX® Universal Compression Connectors A BELDEN BRAND Series 7 & 11 Series Cable Installers are faced with the problem of identifying old unmarked 60% through Quad Shield Series 7 & 11 cable, and having to guess which connector is the best match. This results in unnecessary service calls due to the use of the wrong connector/cable match. The unique patented design of the EX® body achieves true universality on 60% through Quad Shield, PE, and PVC jacket. cations Bandwidth 0 MHz to 3 GHz Impedance 75 Ohms (nominal) Return Loss Minimum -30 dB to 3 GHz Insertion Loss Less than .10 dB to 3 GHz Operating Voltage 90 V (at 60 Hz continous AC) Operating Temperature -40o F to + 140o F (-40o C to 60o C) Cable Retention 45 lbs (20.41 kg) minimum ts Screw post design allows for easy installation of cable (11 series connectors) spring contact EPDM o-ring seal A-11 Large tapered compression area creates a redundant moisture-tight interface DROP PRODUCTS CONNECTORS A BELDEN BRAND Application EX® Universal compression connectors used in combination with port seals ensure proper port sealing every time Right angle connectors prevent improper cable bending and tap ports from breaking in smaller pedestals EX® Series Universal Compression Connectors: Series 7 & 11 EX7 EX11 EX11RAFM EX7N716 EX11N716 Part Numbers EX7 EX® Universal compression connector, 9/16’’ hex nut, series 7 cable EX7N716 EX® Universal compression connector, 7/16’’ hex nut, series 7 cable EX11 EX® Universal compression connector, 9/16’’ hex nut, series 11 cable EX11N716 EX® Universal compression connector, 7/16’’ hex nut, series 11 cable EX11RAFM EX® Universal compression connector, right angle, 9/16’’ hex nut, series 11 cable V T200 VT300 DDT59611 T W307 AH TW309 Preparation & Installation Tools Compression Tool V T200 ¼” – ¼” universal drop cable preparation tool LDT596-250 9/16’’ snap torque wrench T W309 7/16’’ snap torque wrench T W207 V T300 CATAS CAT-AS-EX DDT59611 T W309 T W307 AH A-12
很抱歉,暂时无法提供与“EX11”相匹配的价格&库存,您可以联系我们找货
