H155A01.00B100
H155A01.00B100
    BELDEN
    BELDEN - H155A01.00B100 - Coaxial Cable, RG58/U, 16 AWG, 50 ohm, 328 ft, 100 m
H155A01.00B100 数据手册
Part Number: H155A01 COAX RF H155 PE Product Description COAX RF [1.4/3.9] H155 STRANDED PE Technical Specifications Product Overview Environmental Space: Outdoor Suitable Applications: 50 Ohm low loss coaxial transmission cable designed according European Standard EN 50117-1; Operating Frequencies between 5 and 6000 MHZ Physical Characteristics (Overall) Conductor AWG Stranding 16 Stranded Material Construction n x D Nominal Diameter Diameter +/- Tolerance No. of Coax BC - Bare Copper 19x0.28 mm Conductor Count: 1.41 mm 0.03 mm 1 1 Insulation Type Material Nominal Diameter Diameter +/- Tolerance Dielectric FPE - Foamed Polyethylene 3.9 mm 0.15 mm Insulation, Table Note: Centricity min. 85% Outer Shield Material Type Layer Material Coverage [%] Min. Overlap Nominal Diameter Diameter +/- Tolerance Coverage +/- Tolerance Tape 1 Aluminum/Polyester/Aluminum Braid 2 TC - Tinned Copper 2 mm 80 % 4.5 mm 0.25 mm Outer Jacket Material Material Nominal Diameter Diameter +/- Tolerance PE - Polyethylene 5.4 mm 0.2 mm Construction and Dimensions Min Elongation at Breakof Jacket: 150 % Min Tensile Strength of Jacket: 12.5 MPa Electrical Characteristics Conductor DCR Max. Conductor DCR Max. Conductor Loop Max. Shield DCR 15.4 Ohm/km 32.4 Ohm/1000ft 17 Ohm/km Capacitance Nom. Capacitance Capacitance Tolerance 84 pF/m 3 pF/m Impedance Nominal Characteristic Impedance Nominal Characteristic Tolerance Regularity of Impedance 50 Ohm 3 Ohm Min. 40 dB 5% High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 5 MHz 2.5 dB/100m 50 MHz 6.9 dB/100m 100 MHz 9.1 dB/100m 230 MHz 13.4 dB/100m 400 MHz 18 dB/100m 800 MHz 26.1 dB/100m 862 MHz 27.3 dB/100m 1000 MHz 29.6 dB/100m 1350 MHz 34.9 dB/100m 1750 MHz 40.3 dB/100m 2150 MHz 46 dB/100m 2400 MHz 49.1 dB/100m 3000 MHz 56.3 dB/100m 3600 MHz 62.9 dB/100m 4200 MHz 69.1 dB/100m 4800 MHz 75.1 dB/100m 5400 MHz 80.8 dB/100m 6000 MHz 86.5 dB/100m Delay Nominal Velocity of Propagation (VP) [%] Velocity of Propagation Tolerance 80 % 2% High Freq Frequency [MHz] Min. RL (Return Loss) [dB] 5 - 30 MHz 20 dB 30 - 470 MHz 20 dB 470 - 1000 MHz 18 dB 1000 - 2000 MHz 16 dB 2000 - 3000 MHz 15 dB 3000 - 6000 MHz 15 dB High Freq Table Note: In each frequency band, 3 peak values up to 4 dB lower are allowed, values above 3000 MHZ for information only Screening Frequency [MHz] Min. Screening Attenuation 30 - 1000 MHz 85 dB Voltage Voltage Test Dielectric 2.0 kV DC Temperature Range Installation Temp Range: -5°C To +50°C Storage Temp Range: -30°C To +70°C Operating Temp Range: -30°C To +70°C Mechanical Characteristics Max Recommended Pulling Tension: 100 N Min Bend Radius (W/o Pulling Strength): 60 mm Crush Resistance: Max. 1% (load of 700N) N Adhesion Dielectric: 5-50 N at 25 mm N Standards CENELEC Compliance: EN 50117-1, EN 50117-2-5 and EN 50290-2-20 RG Type: 58/U Type Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 1998-01-01 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1-2 Amount of Halogen acc. to IEC 60754-1 & EN50267-1: Zero Part Number Variants Color Length H155A01.001000 Black Item # 1,000 m H155A01.00B100 Black 100 m History Update and Revision: Revision Number: 0.153 Revision Date: 08-22-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
H155A01.00B100 价格&库存
很抱歉,暂时无法提供与“H155A01.00B100”相匹配的价格&库存,您可以联系我们找货
H155A01.00B100
    • 1+2997.00858
    库存:900
