HP28SBA-0725
HP28SBA-0725
    BELDEN
    BELDEN - HP28SBA-0725 - WIRE, PTFE, A, BROWN, 7/0.12MM, 25M
HP28SBA-0725 数据手册
VR1127 DATE: 27/03/2007 ORIGINATOR: A.J.R. CHECKED: BELDEN CDT- SPECIFICATION DATA SHEET CABLE TYPE PTFE INSULATED EQUIPMENT WIRE GENERAL DESCRIPTION SILVER AND NICKEL PLATED COPPER CONDUCTORS, PTFE INSULATED TYPE A (SPCW) AND NA (NPCW). RELEVANT STANDARDS BS 3G 210 : 1996 Conductor Details Insulation Thickness Overall Diameter Conductor Resistance (Ω/km @ 20°C) Size Stranding O/D Area Min. Max. Min. Max. SPCW NPCW AWG (mm) (mm) (mm²) (mm) (mm) (mm) (mm) (Max) (Max) 30 01/0.250 0.25 0.049 0.10 0.15 0.45 0.60 377.00 387.00 28 01/0.320 0.32 0.080 0.10 0.15 0.52 0.67 229.00 234.00 26 01/0.400 0.40 0.126 0.10 0.15 0.60 0.75 146.00 148.00 32 07/0.080 0.24 0.035 0.10 0.15 0.44 0.59 558.00 605.00 30 07/0.100 0.30 0.055 0.10 0.15 0.50 0.65 353.00 377.00 28 07/0.120 0.36 0.079 0.10 0.15 0.56 0.71 244.00 258.00 26 07/0.150 0.45 0.124 0.10 0.15 0.65 0.80 159.00 166.00 24 07/0.200 0.60 0.220 0.10 0.15 0.80 0.95 88.30 91.20 26 19/0.100 0.50 0.149 0.10 0.15 0.70 0.85 130.00 139.00 24 19/0.120 0.60 0.215 0.10 0.15 0.80 0.95 89.80 94.90 22 19/0.150 0.75 0.336 0.10 0.15 0.95 1.10 58.60 61.30 20 19/0.200 1.00 0.597 0.10 0.15 1.20 1.35 32.50 33.60 *Current ratings are based on a temperature rise of 40°C (single wire in free air) Mass Long term current rating Max. *(A) 2.0 3.0 4.0 1.5 2.0 3.0 4.0 6.0 5.0 6.0 8.0 11.0 Max. (kg/km) 0.96 1.32 1.83 0.84 1.10 1.40 1.96 3.04 2.26 2.99 4.41 7.19 CABLE CHARACTERISTICS : VOLTAGE RATING: 300 V rms TEMPERATURE RATING: -75°C to +190°C for SILVER plated copper conductors -75°C to +260°C for NICKEL plated copper conductors PTFE is unaffected by oils, lubricants, hydraulic fluids and aircraft fuel. The material is non flammable, resistant to solder iron damage and is highly flexible. Although widely used for high performance aerospace applications, PTFE wires are used in environments where the demands, whether thermal, electrical or mechanical, are severe. Available in 11 basic colours Black, Brown, Red, Orange, Yellow, Green, Blue, Violet, Grey, White, Pink (plus natural) along with bi- and tri- colour combinations. PTFE Insulation is applied either by extrusion, or by spiral lapping and sintering. All extruded wire sizes/colours are RoHS compliant Information in this publication and otherwise supplied to users is based on our general experience and is given in good faith , but because of the many particular factors which are outside our knowledge which affect the use of products, no warranty is given nor is implied with respect to such information. Users should make their own enquiries to determine the suitability of products for any particular use. Freedom under patents, copyright and registered designs cannot be assumed. This design may be subject to change without notification - please check this data sheet is still current.
HP28SBA-0725 价格&库存
很抱歉,暂时无法提供与“HP28SBA-0725”相匹配的价格&库存,您可以联系我们找货
