Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1505F Coax - RG-59/U Type
For more Information
please call
1-800-Belden1
General Description:
22 AWG stranded (7x29) .031" bare compacted copper conductor, gas-injected foam HDPE insulation,
tinned copper double braid shield (95% coverage), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
22
7x29
Dia. (in.)
BCC - Bare Compacted Copper .031
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
Gas-injected FHDPE - Foam High Density Polyethylene .145
Outer Shield
Outer Shield Material:
Layer # Type Outer Shield Material Coverage (%)
1
Braid TC - Tinned Copper
95.000
2
95.000
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Overall Cable
Overall Nominal Diameter:
0.242 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-35°C To +75°C
UL Temperature Rating:
75°C
Bulk Cable Weight:
41 lbs/1000 ft.
Max. Recommended Pulling Tension:
88 lbs.
Min. Bend Radius/Minor Axis:
2.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CM
CEC/C(UL) Specification:
CM
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
59/U
Page 1 of 3
01-05-2017
Flame Test
UL Flame Test:
UL1685 UL Loading
Suitability
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
75
Nom. Inductance:
Inductance (µH/ft)
0.094
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
17.0
Nominal Velocity of Propagation:
VP (%)
80
Nominal Delay:
Delay (ns/ft)
1.3
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
12.2
Nominal Outer Shield DC Resistance:
2.4
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1.000
0.200
3.600
0.500
5.000
0.600
6.000
0.670
7.000
0.730
10.000
0.900
12.000
0.980
25.000
1.440
67.500
2.400
71.500
2.500
88.500
2.800
100.000
3.000
135.000
3.500
143.000
3.600
180.000
4.100
270.000
5.100
360.000
6.000
540.000
7.500
720.000
8.900
750.000
9.100
1000.000
10.800
1500.000
13.600
2000.000
16.100
2250.000
17.300
3000.000
20.700
4500.000
26.700
Max. Operating Voltage - UL:
Voltage
300 V RMS
Other Electrical Characteristic 1:
Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge
and termination.
Other Electrical Characteristic 2:
Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, using a 75 Ohm fixed bridge and
Page 2 of 3
01-05-2017
termination.
Minimum Return Loss:
Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB)
5.000
850.000
20.000
851.000
4500.000
15.000
Sweep Test
Sweep Testing:
100% Sweep tested 5 MHz to 4.5 GHz.
Notes (Overall)
Notes: Compacted conductor combines impedance uniformity of solid conductors and "nick-resistance" of stranded conductor.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1505F B591000
1,000 FT
45.000 LB
BLACK, MATTE
C
#21 GIFHDLDPE DBLB PVC
1505F G7V1000
1,000 FT
45.000 LB
RED, MATTE
C
1505F G7W1000
1,000 FT
45.000 LB
GREEN, MATTE
C
1505F G7X1000
1,000 FT
45.000 LB
BLUE, MATTE
C
1505F G7Y1000
1,000 FT
45.000 LB
WHITE, MATTE
C
1505F G8L1000
1,000 FT
45.000 LB
ORANGE, MATTE
C
1505F Z4B1000
1,000 FT
45.000 LB
VIO Z4B
1505F 0041000
1,000 FT
45.000 LB
YELLOW
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 11
Revision Date: 06-17-2016
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“1505F B591000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+15.192591000+1.96482
