1505S3 0001000
1505S3 0001000
    BELDEN
    BONDED FILLER COMPOSITE
1505S3 0001000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1505S3 Coax - RG-59/U Type For more Information please call 1-800-Belden1 General Description: 20 AWG solid .032” bare copper conductors, gas-injected foam HDPE insulation, Duofoil® (100% coverage) plus a tinned copper braid shield (95% coverage), individual PVC jackets. Usage (Overall) Suitable Applications: RGB, VGA, SVGA, XGA, SXGA, UXGA, HDTV, LCD, Plasma, Digital Signage, Component Video, Video Mult, Animation, Special Effects, Suitable for use in Risers Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 3 20 Solid BC - Bare Copper .032 Total Number of Conductors: 3 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .145 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material 1 Duofoil® Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 2 Braid TC - Tinned Copper 95 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride .235 Inner Jacket Color Code Chart: Number Color 1 Red 2 Green 3 Blue Outer Jacket Outer Jacket Material: Outer Jacket Material Unjacketed Overall Cable Overall Cabling Fillers: Bonded Spline Overall Nominal Diameter: 0.502 in. Mechanical Characteristics (Overall) Operating Temperature Range: -35°C To +75°C UL Temperature Rating: 60°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 97 lbs/1000 ft. Max. Recommended Pulling Tension: 216 lbs. Min. Bend Radius/Minor Axis: 6.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1505S3 Coax - RG-59/U Type CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: UL1666 Vertical Shaft Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.107 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.2 Nominal Velocity of Propagation: VP (%) 83 Nominal Delay: Delay (ns/ft) 1.22 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 10.0 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.8 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.3 3.6 0.6 10 0.9 71.5 2.1 135 2.7 270 3.8 360 4.4 540 5.5 720 6.4 750 6.5 1000 7.6 1500 9.4 2500 12.4 3000 13.8 Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1505S3 Coax - RG-59/U Type Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge and termination. Other Electrical Characteristic 2: Return Loss Tested in Accordance With ASTM D-4566 Paragraph 45.3, Using a 75 Ohm Fixed Bridge and Termination. Minimum Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5 475 20 475 525 15 525 850 20 850 4500 15 Sweep Test Sweep Testing: Sweep tested 5 MHz to 4.5 GHz. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1505S3 0001000 1,000 FT 103.000 LB NONE C BONDED FILLER COMPOSITE 1505S3 000500 500 FT 55.000 LB NONE C BONDED FILLER COMPOSITE Notes: C = CRATE REEL PUT-UP. Revision Number: 0 Revision Date: 02-28-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1505S3 0001000 价格&库存
很抱歉,暂时无法提供与“1505S3 0001000”相匹配的价格&库存,您可以联系我们找货
