1588A 0061000
1588A 0061000
    BELDEN
    CAT5E 2PR U/UTP CMR REEL
1588A 0061000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1588A Multi-Conductor - Category 5e Nonbonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT5e (200MHz), 2-Pair, U/UTP-Unshielded, Riser-CMR, Premise Horizontal Cable, 24 AWG Solid Bare Copper Conductors, Polyolefin Insulation, Ripcord, PVC Jacket Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422 Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 24 Solid BC - Bare Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.183 Outer Jacket Ripcord: Yes Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange Mechanical Characteristics (Overall) Storage Temperature Range: -20°C To +75°C Installation Temperature Range: 0°C To +60°C Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 15 lbs/1000 ft. Max. Recommended Pulling Tension: 13 lbs. Min. Bend Radius/Minor Axis: 1 in. Min. Bend/Installation: 1.800 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes Page 1 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1588A Multi-Conductor - Category 5e Nonbonded-Pair Cable EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 5e - TIA 568.C.2 Other Specification: NEMA WC-63.1 Category 5e, UL verified to Category 5e Flame Test UL Flame Test: UL1666 Vertical Riser C(UL) Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: No Suitability - Aerial: No Suitability - Burial: No Sunlight Resistance: No Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1590A Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 45 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.38 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 5 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) Min. SRL (dB) 1 2.0 65.3 62.3 63.0 60.3 20.0 23.0 4 4.1 56.3 53.3 51.0 49.2 23.0 23.0 8 5.8 51.8 48.8 46.0 43.0 24.5 24.5 10 6.5 50.3 47.3 43.0 40.8 25.0 25.0 16 8.2 47.3 44.3 39.0 36.0 25.0 25.0 20 9.3 45.8 42.8 36.5 33.5 25.0 25.0 Page 2 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1588A Multi-Conductor - Category 5e Nonbonded-Pair Cable 25 10.4 44.3 41.3 33.9 30.9 24.3 24.3 31.25 11.7 42.9 39.9 31.0 28.2 23.6 23.6 62.5 17.0 38.4 35.4 22.0 19.0 21.5 21.5 100 22.0 35.3 32.3 14.0 10.3 20.1 20.1 155 28.1 32.5 29.5 4.4 1.4 15.8 200 32.0 30.8 27.8 4.0 1.0 15.0 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 100 ± 15 63.8 60.8 4 100 ± 15 100 ± 15 51.7 48.7 8 100 ± 15 100 ± 15 45.7 42.7 10 100 ± 15 100 ± 15 43.8 40.8 16 100 ± 15 100 ± 15 39.7 36.7 20 100 ± 15 100 ± 15 37.7 34.7 25 100 ± 15 100 ± 15 35.8 32.8 31.25 100 ± 15 100 ± 15 33.9 30.9 62.5 100 ± 15 100 ± 15 27.8 24.9 100 100 ± 15 100 ± 15 23.8 20.8 155 100 ± 25 100 ± 15 19.9 16.9 200 100 ± 25 100 ± 15 17.7 14.7 Notes (Overall) Notes: Jacket sequentially marked at 2 ft. intervals. Third party verified to ANSI/TIA-568-C.2, Category 5e. Put Ups and Colors: Item # Putup Ship Weight Color 1588A F6HU1000 1,000 FT 15.000 LB GRAY, DARK PEARL Notes 1588A F6H1000 1,000 FT 15.000 LB GRAY, DARK PEARL 1588A F6H1640 1,640 FT 24.600 LB GRAY, DARK PEARL 1588A 006U1000 1,000 FT 15.000 LB BLUE, LIGHT 1588A 0061000 1,000 FT 15.000 LB BLUE, LIGHT Item Desc CAT5E 2PR U/UTP CMR BOX C CAT5E 2PR U/UTP CMR REEL CAT5E 2PR U/UTP CMR REEL CAT5E 2PR U/UTP CMR BOX C CAT5E 2PR U/UTP CMR REEL Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 08-06-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 02-01-2017
1588A 0061000 价格&库存
很抱歉,暂时无法提供与“1588A 0061000”相匹配的价格&库存,您可以联系我们找货
1588A 0061000
  • 1000+3.051411000+0.39422
