1667E.00305
1667E.00305
    BELDEN
    BELDEN - 1667E.00305 - Networking Cable, Unscreened, Cat5e, 24 AWG, 0.204 mm², 1000 ft, 304.8 m
1667E.00305 数据手册
Product Datasheet P/N - 46101 Rev.3A Page 1 of 2 Date 01-05-2001 Belden 1667E TWIN CAT 5 enhanced UTP PVC Application • • Horizontal and building backbone cable. Support current Category 5 and Category 5 enhanced applications, such as: 10 Base-T, 100 Base-T, 1000 Base-T (Gigabit Ethernet), FDDI, ATM Standards • • General standards: Future standards like: ISO/IEC 11801, EN 50173, TIA/EIA 568-A-5 enhanced ISO/IEC 11801 2nd edition, EN 50173 2nd edition und prEN 50288-3-1 Construction & Dimensions • • • • • • • Construction: Conductor: Conductor diameter: Conductor insulation material: Diameter over insulation: Jacket material: Outer diameter: Unshielded 2x4 twisted pairs solid bare copper AWG 24 (0,51 mm) Polyethylene (PE) 0.90 mm ± 0.05 mm PVC (Flame retardant) 5.0 mm ± 0.3 mm x 10.5 mm Colour code Pair 1 Pair 2 Pair 3 Pair 4 White-Blue/Blue White-Orange/Orange White-Green/Green White-Brown/Brown Electrical characteristics (at 20 ºC) Attenuation Frequency 1) Spec. (Max.) Typical 4 4.0 3.9 10 6.3 6.2 16 8.0 7.9 20 9.0 8.9 31.25 11.4 11.2 62.5 16.5 16.0 100 21.3 19.8 MHz dB/100m dB/100m NEXT (Near end crosstalk) Frequency 1 4 1) Spec. (Min.) 60.0 56.3 Typical 73 64 10 50.3 58 16 47.3 55 20 45.8 54 31.25 42.9 51 62.5 38.4 47 100 35.3 44 MHz dB dB Power sum NEXT Frequency 1 1) Spec. (Min.) 57.0 Typical 71 4 53.3 62 10 47.3 56 16 44.3 53 20 42.8 52 31.25 39.9 49 62.5 35.4 45 100 32.3 42 MHz dB/100m dB/100m Power sum ELFEXT Frequency 1 1) Spec. (Min.) 60.8 Typical 71 4 48.7 59 10 40.8 51 16 36.7 46 20 34.7 43 31.25 30.9 39 62.5 24.8 33 100 20.8 28 MHz dB/100m dB/100m 1 56 71 4 52 61 10 44 52 16 39 48 20 37 45 31.25 31 40 62.5 22 31 100 14 24 MHz dB/100m dB/100m Power sum ACR Frequency 1 1) Spec. (Min.) 53 Typical 69 4 49 59 10 41 50 16 36 46 20 34 43 31.25 28 38 62.5 19 29 100 11 22 MHz dB/100m dB/100m ACR Frequency 1) Spec. (Min.) Typical 1) 1 4.0 1.9 : Specification values according to cable requirements of ISO/IEC 11801 category 5 enhanced Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner. All printing errors are subject to correction. Technical apecifications are subject to change without notice. Product Datasheet P/N - 46101 Rev.3A Page 2 of 2 Date 01-05-2001 Belden 1667E TWIN CAT 5 enhanced UTP PVC Electrical characteristics (at 20 ºC) Nominal mutual capacitance at 1 kHz Maximum conductor DCR NVP - Nominal Velocity of Propagation SKEW – Propagation delay difference (100 MHz) Impedance 1 - 100 MHz 50 nF/km 93.5 Ohm/km 0.70 c typical ≤ 15 ns/100m 100 ± 15 Ohm General and environmental characteristics Temperature range - operation Temperature range - installation Minimum bending radius - operation Minimum bending radius - installation Maximum pulling tension Flame retardancy Energy of flame Weight (approx.) Maximum operating voltage Maximum continuous current per conductor (25°C) -20°C - +60°C +0°C - +50°C 20 mm 40 mm 80 N IEC 332-1 600 kJ/m 56 kg/km 48 V rms 1.4 A Ordering information MARKING Text on the cable jacket Inkjet printing BELDEN 1667E UTP CAT5E 2x4PR AWG24 ISO/IEC 11801 EN 50173 VERIFIED 100 OHM Meter marking: JACKET COLOUR Colour Grey Yes RAL code RAL 7032 PACKAGING (PUT UP) Belden code Delivery length 46101 xxxx 079 305 m 46101 xxxx 240 500 m xxxx: Belden colour code Belden colour code 2833 Weight 17.0 kg 28,0 kg Remark Non returnable reel Non returnable reel Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner. All printing errors are subject to correction. Technical apecifications are subject to change without notice.
1667E.00305 价格&库存
很抱歉,暂时无法提供与“1667E.00305”相匹配的价格&库存,您可以联系我们找货
