C501108010
C501108010
    BELDEN
    模块化电缆 插头至插头 8p8c(RJ45,以太网) 10.00'(3.05m) 无屏蔽
C501108010 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION C501108010 Cable Assemblies - CAT5E Modular Cord For more Information please call 1-800-Belden1 General Description: CAT5E Patch Cord, Bonded-Pair, 4 Pair, 24 AWG Solid, CMR, T568A/B-T568A/B, Gray, 10 ft. (3.0 m). Usage (Overall) Suitable Applications: IBDN System 1200, TIA Category 5E, ISO Class D, 1000BASE-T, 100BASE-T Related Parts: CAT5E Modular Jacks, CAT5E Patch Panels Multi Conductor Physical Characteristics Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Color Code Chart: Color Gray Overall Diameter Overall Nominal Diameter: 0.208 in. Individual Cable Diameter: 0.240 in. Physical Characteristics (Connectivity) Materials Materials: Description Type Material Plug RJ45 Polycarbonate Boot Rubber Front Connection Blades Phosphor Bronze with 50u inch Gold over Nickel Plating Color Boot Color: Translucent Wiring Scheme Wiring Scheme: T568A/B Weight Weight: 0.060 lbs. Packaging Packaging: Individually packaged in a clear plastic bag. Mechanical Characteristics (Connectivity) Plug / Jack Compatibility: RJ45 Termination Interface: Termination Connection RJ45 Durabilities Mated Connection 750 Cycles Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Page 1 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION C501108010 Cable Assemblies - CAT5E Modular Cord Operating Temperature Range: -10°C To +60°C Max. Recommended Pull Tension: 25 lbs. Min. Bend Radius (Overall Cable): 1.040 in. Environmental/Mechanical Characteristics: Test (Method) TIA 568-D.3 Belden Thermal Cycling (FOTP-3) n/a -40 to 75°C cycling for 7 days Temperature Life (FOTP-4) 60°C for 4 days 85°C for 7 days Humidity (FOTP-5) 90-95% at 40°C for 4 days 95% @ 75°C for 7 days Durability (FOTP-21) 500 cycles 6 x 200 cycles (3 Elevations) Cable Retention (FOTP-6) 5.0 kg @ 0 deg. 1.94 kg @90 deg. Flex (FOTP-1) 0.5 kg @ 90° to -90° for 100 cycles 0.9 kg @ 90° to -90° for 100 cycles Twist (FOTP-36) 1.5 kg for 10 cycles 1.5 kg for 10 cycles Overall Length Tolerances: Range Tolerance Range Sx & Dx Patchcord Sx & Dx Patchcord MPO Trunk Tolerance Range MPO Trunk Multi-Fiber Cable Assembly Multi-Fiber Cable Assembly Tolerance 0 to 2 meters +0.2 / -0 meter 0 to 2 meters +0.2 / -0 meter 0 to 2 meters 2.1 to 5.0 meters +0.3 / -0 meter 2.1 to 5.0 meters +0.3 / -0 meter 2.1 to 5.0 meters +0.3 / -0 meter 5.1 to 40 meters +0.4 / -0 meter 5.1 to 20 meters +0.4 / -0 meter Over 40.1 meters + 1.0% / -0% Over 20.1 meters + 1.0% / -0% +0.4 / -0 meter 5.1 to 20 meters Over 20.1 meters +0.2 / -0 meter + 1.3 / -0 meter Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: Riser Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2006 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: Category 5e - TIA 568.B.2, Category 5 - ISO/IEC 11801:2002 Ed.2 Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes Transmission Characteristics (Connectivity) Optical Connector Performance: Description OM1 OM2 OM3 OM4 OS2 / UPC OS2 / APC Maximum Insertion Loss (dB) 0.5 dB 0.5 dB 0.5 dB 0.15 dB 0.5 dB 0.5 dB Minimum Reflectance (dB) - 65 dB -20 dB -20 dB -20 dB -20 dB -50 dB Performance Table 1: Max. Min. Min Min. Min. Frequency Max. Insertion Loss Insertion Loss PSNEXT PSNEXT PSACRF PSACRF (MHz) TIA* (dB) Belden (dB) TIA* (dB) Belden (dB) TIA* (dB) Belden (dB) 1.000 2.400 2.000 62.300 65.300 60.800 60.800 4.000 4.900 4.000 53.300 56.300 48.800 48.800 8.000 6.900 5.700 48.800 51.800 42.700 42.700 10.000 7.800 6.400 47.300 50.300 40.800 40.800 16.000 9.900 8.100 44.200 47.300 36.700 36.700 20.000 11.100 9.200 42.800 45.800 34.800 34.800 25.000 12.500 10.300 41.300 44.300 32.800 32.800 31.250 14.100 11.600 39.900 42.900 30.900 30.900 62.500 20.400 16.800 35.400 38.400 24.900 24.900 100.000 26.400 21.700 32.300 35.300 20.800 20.800 160.000 28.200 Performance Table - Footnote: 32.300 16.700 100 Meter Cable Specifications - * TIA-EIA-568-B.2 Category 5e Standard -------- PSACRF is formally PSELFEXT Performance Table 2: Min. Min. Frequency (MHz) Return Loss Return Loss TIA* (dB) Belden (dB) 1.000 20.000 20.000 4.000 23.000 23.000 8.000 24.500 24.500 10.000 25.000 25.000 16.000 25.000 25.000 Page 2 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION C501108010 Cable Assemblies - CAT5E Modular Cord 20.000 25.000 25.000 25.000 24.200 25.000 31.250 23.300 25.000 62.500 20.700 25.000 100.000 19.000 20.000 160.000 19.000 Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Notes (Overall) Product Family Product List: Length Yellow 2 ft. (0.6 m) C501104002 C501105002 C501106002 C501108002 C501109002 C501100002 Green Blue Gray White Black 4 ft. (1.2 m) C501104004 C501105004 C501106004 C501108004 C501109004 C501100004 7 ft. (2.1 m) C501104007 C501105007 C501106007 C501108007 C501109007 C501100007 10 ft. (3.0 m) C501104010 C501105010 C501106010 C501108010 C501109010 C501100010 15 ft. (4.6 m) C501104015 C501105015 C501106015 C501108015 C501109015 C501100015 25 ft. (7.6 m) C501104025 C501105025 C501106025 C501108025 C501109025 C501100025 Put Ups and Colors: Item # Putup Ship Weight Color C501108010 1 EA 0.261 LB GRAY 1SR Revision Number: 0 Notes Item Desc PATCHCORD BCAT5E CMR GRY 10FT Revision Date: 06-08-2009 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 02-27-2017
C501108010 价格&库存
很抱歉,暂时无法提供与“C501108010”相匹配的价格&库存,您可以联系我们找货
C501108010
  • 1+107.154551+12.80865
  • 10+82.2813510+9.83545
  • 25+74.3487925+8.88723
  • 50+68.9832150+8.24586
  • 100+64.11696100+7.66418
  • 250+58.37518250+6.97784
  • 500+54.50528500+6.51525
  • 1000+51.004491000+6.09679
库存:9
