1673J 010100
1673J 010100
    BELDEN
    #19 TFE BRD TINNED COAX PVC
1673J 010100 数据手册
Part Number: 1673J 50 Ohm Microwave, RG402, #19 SPCCS, PVC Jacket Product Description RG-402/U type, 19 AWG solid .036" silver-plated copper-covered steel conductor, TFE Teflon® Insulation, copper-tin composite shield (100% coverage), PVC jacket. Technical Specifications Product Overview Environmental Space: Indoor/Outdoor Physical Characteristics (Overall) Conductor AWG Stranding 19 Solid Material Nominal Diameter No. of Coax SPCCS - Silver Plated Copper Covered Steel 0.036 in Conductor Count: 1 AWG Size: 19 1 Insulation Material Material Trade Name Nominal Diameter TFE - Tetrafluoroethylene Teflon® 0.116 in Outer Shield Material Type Layer Material Coverage [%] Tape 1 Copper Foil Braid 2 Tin-Filled Composite 100 % 100 % Outer Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.178 in Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Conductor DCR Conductor Resistance Nominal Outer Shield DCR Outer Conductor DCR 20.5 Ohm/1000ft 20.5 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Shield 29.5 pF/ft Inductance Nominal Inductance 0.07 µH/ft Impedance Nominal Characteristic Impedance 50 Ohm High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 4.5 Ohm/1000ft 4.5 Ohm/1000ft 500 MHz 8 dB/100ft 1000 MHz 12 dB/100ft 2000 MHz 18.1 dB/100ft 3000 MHz 22.9 dB/100ft 5000 MHz 31 dB/100ft 7000 MHz 37.8 dB/100ft 10000 MHz 46.6 dB/100ft 15000 MHz 59.1 dB/100ft 18000 MHz 65.8 dB/100ft 20000 MHz 70 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.46 ns/ft 69.5 % High Freq Frequency [MHz] Max. Insertion Loss (Attenuation) 500 MHz 9.5 dB/100ft 1000 MHz 14.5 dB/100ft 3000 MHz 26.5 dB/100ft 5000 MHz 36 dB/100ft 10000 MHz 54 dB/100ft 20000 MHz 84 dB/100ft Power Rating Frequency [MHz] Max. Power Rating [W] Nominal Power Rating [W] 500 MHz 600 W 600 W 1,000 MHz 401 W 401 W 2,000 MHz 268 W 268 W 3,000 MHz 211 W 211 W 5,000 MHz 157 W 157 W 7,000 MHz 129 W 129 W 10,000 MHz 105 W 105 W 15,000 MHz 83 W 83 W 18,000 MHz 74 W 74 W 20,000 MHz 70 W 70 W Voltage Non-UL Voltage Rating UL Voltage Rating 1900 V RMS 30 V RMS VSWR Element Frequency [MHz] Max. VSWR Ramp Function, End Points 500 MHz 20000 MHz 1.1 1.3 Temperature Range Non-UL Temp Rating: 105°C UL Temp Rating: 105°C Operating Temp Range: -40°C To +105°C Mechanical Characteristics Bulk Cable Weight: 32 lbs/1000ft Max Recommended Pulling Tension: 70 lbs Min Bend Radius (Overall): 1.5 in Min Bend Radius During Installation: 0.25 in Min Bend Radius/Installation: 0.25 in Min Flexing Radius: 0.75 in Standards UL AWM Style: UL Style 10245 RG Type: RG-402/U Type Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/11/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: No EU RoHS Compliance Date (yyyy-mm-dd): 2005-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Flammability, LS0H, Toxicity Testing Other Flammability: Horizontal Wire Part Number Plenum (Y/N): No Variants Item # Color Footnote 1673J 010100 BLACK C 1673J 010500 BLACK C V Footnote: C - CRATE REEL PUT-UP. Footnote: V - 250' PUT-UP EXACT LENGTH MAXIMUM OF 3 PIECES, MINIMUM LENGTH 50'. 500' PUT-UP EXACT LENGTH MAXIMUM OF 5 PIECES, MINIMUM LENGTH 50'. 1000' PUT-UP EXACT LENGTH MAXIMUM OF 8 PIECES, MINIMUM LENGTH 50'. Product Notes Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
1673J 010100 价格&库存
很抱歉,暂时无法提供与“1673J 010100”相匹配的价格&库存,您可以联系我们找货
