1800B 007U1000
1800B 007U1000
    BELDEN
    #24 FHDPE FS PR PVC
1800B 007U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1800B Multi-Conductor - Single-Pair Cable For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (7x32) tinned copper conductors, Datalene® insulation, twisted pairs, overall Beldfoil® shield (100% coverage), 24 AWG drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 24 7x32 TC - Tinned Copper .024 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® Dia. (in.) FHDPE - Foam High Density Polyethylene .068 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.185 in. Pair Pair Color Code Chart: Number Color 1 Red & Black Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +60°C Bulk Cable Weight: 16 lbs/1000 ft. Max. Recommended Pulling Tension: 16.500 lbs. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1800B Multi-Conductor - Single-Pair Cable CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: AES/EBU Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1801B Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 110 Nom. Inductance: Inductance (µH/ft) .18 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 12 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 26 Nominal Velocity of Propagation: VP (%) 76 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 23.7 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 0.384 0.290 0.706 0.710 0.768 0.770 1.024 0.940 1.411 1.100 1.536 1.100 2.048 1.300 2.822 1.400 3.072 1.400 4.096 1.500 5.645 1.700 6.144 1.800 8.192 2.000 11.290 2.200 12.288 2.300 24.576 3.100 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.75 Amps per conductor @ 25°C Notes (Overall) Notes: For cross-connect use with 1803F (et al.) Digital Audio Snake Cables. The jacket and shield are bonded so both can be removed with automatic stripping equipment. Put Ups and Colors: Item # Putup Ship Weight Color 1800B T5XU1000 1,000 FT 17.000 LB GRAY T5X 1800B T5X1000 1,000 FT 18.000 LB GRAY T5X Page 2 of 3 Notes Item Desc #24 FHDPE FS PR PVC C #24 FHDPE FS PR PVC 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1800B Multi-Conductor - Single-Pair Cable 1800B T5X500 500 FT 9.500 LB GRAY T5X 1800B 007U1000 1,000 FT 17.000 LB VIOLET 1800B 0071000 1,000 FT 18.000 LB VIOLET C #24 FHDPE FS PR PVC #24 FHDPE FS PR PVC C #24 FHDPE FS PR PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 02-29-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
1800B 007U1000 价格&库存
很抱歉,暂时无法提供与“1800B 007U1000”相匹配的价格&库存,您可以联系我们找货
1800B 007U1000
  • 1000+10.844101000+1.40922
