1803F Z4B1000
1803F Z4B1000
    BELDEN
    4 #24 FHDPE FS PR PVC FS PVC
1803F Z4B1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1803F Multi-Conductor - Multi-Pair Snake Cable For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (7x32) TC conductor, Datalene® insulation, pairs individually shielded with bonded Beldfoil® with a drain wire and have numbered and color-coded PVC jackets, overall Beldfoil® shield/drain wire + overall PVC jacket w/nylon rip cord. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 4 24 7x32 TC - Tinned Copper .024 Total Number of Conductors: 8 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® Dia. (in.) FHDPE - Foam High Density Polyethylene .068 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: Stranded Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride .167 Inner Jacket Color Code Chart: Number Color 1 Brown and Numbered 1 2 Red and Numbered 2 3 Orange and Numbered 3 4 Yellow and Numbered 4 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 16 Stranded TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.488 in. Pair Pair Color Code Chart: Number Color Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1803F Multi-Conductor - Multi-Pair Snake Cable 1 Red & Black 2 Red & Black 3 Red & Black 4 Red & Black Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +60°C UL Temperature Rating: 60°C Bulk Cable Weight: 100 lbs/1000 ft. Max. Recommended Pulling Tension: 82.500 lbs. Min. Bend Radius/Minor Axis: 5 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: AES/EBU Flame Test UL Flame Test: UL1685 FT4 Loading C(UL) Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 110 Nom. Inductance: Inductance (µH/ft) .18 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 12 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 26 Nominal Velocity of Propagation: VP (%) 76 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 23.7 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 0.384 0.290 0.706 0.710 0.768 0.770 1.024 0.940 1.411 1.100 Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1803F Multi-Conductor - Multi-Pair Snake Cable 1.536 1.100 2.048 1.300 2.822 1.400 3.072 1.400 4.096 1.500 5.645 1.700 6.144 1.800 8.192 2.000 11.290 2.200 12.288 2.300 24.576 3.100 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.75 Amps per conductor @ 25°C Notes (Overall) Notes: Pair jackets and shields are bonded so both strip simultaneously with automatic stripping equipment. Datalene® insulation features include low dielectric constant and a dissipation factor for high-speed, low-distortion data handling. Physical properties include good crush resistance and light weight. Put Ups and Colors: Item # Putup Ship Weight Color 1803F B591000 1,000 FT 111.000 LB BLACK, MATTE Notes Item Desc 1803F Z4B1000 1,000 FT 111.000 LB VIO Z4B C 4 #24 FHDPE FS PR PVC FS PVC 1803F Z4B500 500 FT 57.500 LB VIO Z4B C 4 #24 FHDPE FS PR PVC FS PVC 4 #24 FHDPE FS PR PVC FS PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 03-17-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
1803F Z4B1000 价格&库存
很抱歉,暂时无法提供与“1803F Z4B1000”相匹配的价格&库存,您可以联系我们找货
