1828D 010U1000
1828D 010U1000
    BELDEN
    COAX 75 OHM RG6 18AWG
1828D 010U1000 数据手册
Technical Data Sheet 05/10/2013 Rev. 9 1828D I. DESCRIPTION: -----------SERIES 6, 18 AWG SOLID BARE COPPER COVERED STEEL CONDUCTOR, FOAM POLYETHYLENE INSULATION, DUOBOND(R) II + ALUMINUM BRAID SHIELD, PVC JACKET. II. ELECTRICAL CHARACTERISTICS: --------------------------NOM. IMPEDANCE: 75 OHMS NOM. INDUCTANCE: .097 MICRO-H/FT NOM. CAPACITANCE CONDUCTOR TO SHIELD: 16.2 PF/FT NOM. VELOCITY OF PROPAGATION: 83% NOM. DELAY: 1.2 NS/FT ATTENUATION: NOMINAL MAXIMUM MHZ DB/100' MHZ DB/100' 5 0.5 5 0.67 55 1.4 55 1.60 211 2.6 211 2.87 500 4.1 500 4.48 750 5.1 750 5.59 862 5.5 862 5.98 1000 6.0 1000 6.54 1450 7.8 1450 8.00 1800 8.6 1800 8.80 2250 9.8 2250 10.00 3000 11.3 3000 11.90 MIN. STRUCTURAL RETURN LOSS: 950-2250 MHZ, 15 DB MIN. 2250-3000 MHZ, 10 DB MIN. MAX. OPERATING VOLTAGE: 300 V RMS NOM. CONDUCTOR DC RESISTANCE @ 20 DEG C: 28.0 OHMS/1000' NOM. SHIELD DC RESISTANCE @ 20 DEG C: 9 OHMS/1000' III. PHYSICAL CHARACTERISTICS: ------------------------TEMPERATURE RATING: NOM. WEIGHT/1000': MIN. BENDING RADIUS: MAX. PULLING TENSION: -40 TO +80 DEG C 30 LBS 3.0" 126 LBS © 2013 Belden, Inc. All rights reserved. All information contained herein is confidential. Its use is restricted to authorized Belden personnel or authorized vendors or customers of Belden. Under no circumstances shall this document be duplicated in any form or shown to/discussed with unauthorized personnel without the expressed written consent of Belden. Although Belden makes every reasonable effort to ensure accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability our suitability for a given purpose. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory, or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence, or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. PENG:dob Technical Data Sheet 05/10/2013 Rev. 9 CONDUCTOR MATERIAL & DIA: DIELECTRIC MATERIAL & DIA: SHIELD TYPE: JACKET MATERIAL & DIA: 18 AWG SOLID BARE COPPER COVERED STEEL, .040" GAS INJECTED FOAM POLYETHYLENE, .180" 1ST LAYER-BONDED DUOFOIL(R) 2ND LAYER-60% ALUM BRAID PVC .270" © 2013 Belden, Inc. All rights reserved. All information contained herein is confidential. Its use is restricted to authorized Belden personnel or authorized vendors or customers of Belden. Under no circumstances shall this document be duplicated in any form or shown to/discussed with unauthorized personnel without the expressed written consent of Belden. Although Belden makes every reasonable effort to ensure accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability our suitability for a given purpose. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory, or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence, or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. PENG:dob
1828D 010U1000 价格&库存
很抱歉,暂时无法提供与“1828D 010U1000”相匹配的价格&库存,您可以联系我们找货
