Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
19126 Portable Cordage - UL/CSA Types: SPT-1, SPT-2, SP-1 and HPN
For more Information
please call
1-800-Belden1
General Description:
SPT-2 PVC parallel lamp cord, UL/CSA listed, 300V 60ºC, one conductor polarity ribbed.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
2
16
65x34
BC - Bare Copper
Total Number of Conductors:
2
Type of Cordage:
SPT-2
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
PVC - Polyvinyl Chloride .048
Outer Shield
Outer Shield Material:
Unshielded
Overall Cable
Overall Nominal Diameter:
0.155 x 0.299 in.
Mechanical Characteristics (Overall)
UL Temperature Rating:
60°C
Bulk Cable Weight:
35 lbs/1000 ft.
Min. Bend Radius/Minor Axis:
1.750 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
SPT-2
CSA Specification:
SPT-2
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
CSA Flame Test:
FT2
Plenum/Non-Plenum
Plenum (Y/N):
No
Surface Printing (Overall)
Electrical Characteristics (Overall)
Max. Operating Voltage - UL:
Voltage
Page 1 of 2
01-05-2017
300 V RMS
Max. Recommended Current:
Current
13 Amps per conductor @ 25°C
10 Amps per conductor @ 25°C (over 50 ft.)
Dielectric Withstand Voltage:
1500 V AC Applied for 1 Min.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
19126 010250
250 FT
9.750 LB
BLACK
F
2 #16 PVC PARALLEL
Notes:
F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50'
Revision Number: 2
Revision Date: 11-02-2012
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
01-05-2017
很抱歉,暂时无法提供与“19126 010250”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+29.20892250+3.79079
